savagesam
Posted: Tue Dec 02, 2014 6:22 am Post subject:
Modular W/ drum sounds Subject description: a tour of my first real lunetta build |
Hey everyone! i've been lurking around on here for quite some time and figured i would finally make my presence known! this is my first real build (i've breadboarded some noisemakers but never felt any need to box them up) and i'm very impressed with some of the sounds i've been able to squeeze out of it so far. as of now it has five modules
1-3x40106 clock/tone generators w/ coarse and fine
2-1 4040 divider
3- 2x 40106 vco with trig. and saw outs
4- baby 10 sequencer
5- drum module
the drum module is a paia drumtone board. you can buy them for $50 or so from the paia website, and with a little tweaking work really well. as things go id like to add more sequencing/melody generation modules into the right hand cabinet, and in the left side stick to tone generation (save for the few clock modules). i was thinking of adding a square wave vco and a couple of filters, as well as a mixer. the mixer (hopefully) will have spring reverb on all channels.
i realize it's not entirely lunetta, but a few op-amps ain't so bad!
Description: |
Filesize: |
2.7 MB |
Viewed: |
389 Time(s) |
Description: |
Filesize: |
2.68 MB |
Viewed: |
370 Time(s) |
Description: |
Filesize: |
2.82 MB |
Viewed: |
374 Time(s) |
Description: |
Filesize: |
2.8 MB |
Viewed: |
377 Time(s) |
Description: |
Filesize: |
2.61 MB |
Viewed: |
404 Time(s) |
commathe
Posted: Tue Dec 02, 2014 7:25 pm Post subject:
Very cool! I love the idea of using that kind of board for a front-panel. Must be very easy to work with! Give us some samples! |
richardc64
Audio files: 26
Posted: Wed Dec 03, 2014 1:50 am Post subject:
Re: Modular W/ drum sounds Subject description: a tour of my first real lunetta build |
savagesam wrote: |
the drum module is a paia drumtone board. you can buy them for $50 or so from the paia website, and with a little tweaking work really well. |
Share your tweaks... like I did.
http://electro-music.com/forum/topic-45381.html
Very cool use of peg board. _________________ Revenge is a dish best served with a fork... to the eye |
savagesam
Posted: Sat Dec 13, 2014 10:09 am Post subject:
commathe wrote: | Very cool! I love the idea of using that kind of board for a front-panel. Must be very easy to work with! Give us some samples! |
Thanks! it makes it REALLY easy drilling holes for pots and stuff was thinking of trying to find something creative to do with the left over holes though. possibly some LED tape on the inside? im in the middle of moving/ into a new shop space right now so i dont know when ill be able to get sounds up but ill record some ASAP |
savagesam
Posted: Sat Dec 13, 2014 10:15 am Post subject:
richardc64 wrote: | savagesam wrote: |
Very cool use of peg board. |
The tweaks i used were mostly straight off of the PAIA forum. i just added glide and pitch controls for the Synth Drum and left all the others as is. i kind of liked the raymond scott vibe i was able to get with the wood block/clave sounds. One big thing however was to add another board to convert from square wave to trigger signals. i did this by sending the input through a capacitor with a diode to ground at the other end. it gave me nice percussive taps instead of having the signal be on for the duration of the square wave |
