Left channel drops in level - any ideas what the problem is?
Page 1 of 1 [10 Posts]
kirky
PostPosted: Wed Jan 28, 2015 1:41 pm    Post subject: Left channel drops in level - any ideas what the problem is? Reply with quote  Mark this post and the followings unread
Hi there
I bought an A6 and everything is great, except that sometimes it happens, that the Left Channel drops in Level (about 5 db). I can't find any regularities in when it happens. Sometimes its like this when I start the synth up, sometimes it happens when I turn a poti, sometimes it happens when I just play the keys. Sometimes it jumps right back to the normal level and back again, sometimes it stays at the normal level.
I included two attachement's where you can hear how it sounds when it's jumping around (A6_bug1) and when it's wrong in the beginning and then jumps to the right level and stays there (A6_bug2).
I would be reeeeally glad if somebody could tell me what the issue might be here. Has anybody ever had that problem or has a good guess on what it could be? The next technician is a few car hours aways and I have no car Smile This happens on the headphone outputs as well btw.
Thanks in advance for your help!
A6_bug1.mp3
 Filename:  A6_bug1.mp3
 Filesize:  154.63 KB
 Downloaded:  229 Time(s)
A6_bug2.mp3
 Filename:  A6_bug2.mp3
 Filesize:  78.13 KB
 Downloaded:  196 Time(s)
sunny pedaal
Audio files: 12
PostPosted: Sun Feb 01, 2015 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
you meant the distorted parts?
also on the aux out and or 1 or more the individual outs ?
all patches the same ?
no midi connections?
kirky
PostPosted: Sun Feb 01, 2015 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you listen to headphones it's easy to hear. First the sound is coming from the right (right channel is 4-5 db louder than the left), then there is this noise and suddenly the sound is sitting in the middle, coming from both channels at the same level. Except from playing the keys I didn't do anything in that moment.
This happens on all patches, on all outs.
sunny pedaal
Audio files: 12
PostPosted: Sun Feb 01, 2015 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
no interfering cabling?
might be the output card, something on there
where to find one?
kirky
PostPosted: Wed Feb 04, 2015 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
no interfering cables.
It's happens on all outputs, even headphones...
sunny pedaal
Audio files: 12
PostPosted: Thu Feb 05, 2015 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
probably not on the individual outs....
if so , soundboard i'd say
so far for diagnosis Crying or Very sad
paologatto
PostPosted: Sun Feb 08, 2015 6:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
If the individual voices outputs are ok, maybe it's the mute transistor on the main / headphone output. Check the schematics on the service manual
kirky
PostPosted: Mon Feb 09, 2015 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Checked the service manual but didn't find any schematics. Where do I have to look?
paologatto
PostPosted: Mon Feb 09, 2015 4:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't remember where to find it, but it's not hard to find since the A6 is no more produced. The things to check are in the analog master PCB schematics, sheet 3, check the 4 JFET Q1..Q4 near the MUTE transistor
sunny pedaal
Audio files: 12
PostPosted: Tue Feb 10, 2015 10:40 am    Post subject: Reply with quote  Mark this post and the followings unread
service manual is in first section of this board
ps i meant outputcard when writing soundcard...
