Solar powered tweeting birdhouse
Page 1 of 1 [4 Posts]
PostPosted: Fri Apr 10, 2015 4:35 pm    Post subject: Solar powered tweeting birdhouse
Subject description: no, it doesn't have a twitter account
The circuit for this is based on Wilf's bird sound generator but I modified it a bit. The zenerdiode actually
got in there by accident, it got mixed up with the rest of my diodes and I only noticed it after I soldered
the circuit on perf and it didn't sound like the one on my breadboard (which had the zenerdiode).
I made it about 10 years years ago and than just had it laying around collecting dust. I did have the idea of putting
it in a bird house and a couple months ago I found a small cheap one. It was all glued together so I
carefully had to cut the roof off so I could install the circuit. My initial idea was to put the solar panel on
the roof but since I will be using it inside in front of a window I decided to place it on the back together
with the LDR's. And then I finished it with some green and black paint.
Modified version of Wilf's Bird Sound Generator
 Filesize:  35.72 KB
 Viewed:  740 Time(s)
 Filesize:  65.14 KB
 Viewed:  655 Time(s)
 Filesize:  67.69 KB
 Viewed:  651 Time(s)
 Filesize:  60.14 KB
 Viewed:  638 Time(s)
PostPosted: Fri Apr 10, 2015 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are 2 videos: the first one was recorded when it was still breadboarded, the second one has it transfered to perf, together
with another one with different component values on breadboard (and it's still on there Shocked ).
Solar beeper test.mp4
 Filename:  Solar beeper test.mp4
 Filesize:  5.66 MB
 Downloaded:  803 Time(s)
Solar beepers.mp4
 Filename:  Solar beepers.mp4
 Filesize:  4.97 MB
 Downloaded:  775 Time(s)
bubzy
Audio files: 64
PostPosted: Sat Apr 11, 2015 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Linux
sounds cool and looks great!
_Richard_ Smile
PostPosted: Sat Apr 11, 2015 4:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
" Solar powered tweeting birdhouse "
Had that almost removed as spam Laughing
Works very nice the birdies!
