Codes doesn't work: object scoping / no sound plays
Page 1 of 1 [4 Posts]
makeitgofaster
PostPosted: Wed Jul 01, 2015 5:21 am    Post subject: Codes doesn't work: object scoping / no sound plays Reply with quote  Mark this post and the followings unread
Hiya!
I'm new here and trying to figure out how to get going on this CHucK stuff.
I have the code below, which does not play any sound. Essentially, I'm trying to build a class to represent an arbitrary listing of notes to be played as a chord.
Two questions:
1) In test_play, I'm throwing an oscillator declared in the while loop to DAC. When I wait outside the loop, those are still "thrown to DAC" and don't magically disappear because I'm out of scope of the loop, right?
2) Other code examples I can run are making sound... why isn't this working?
Code:
public class ratiochord
 10 => int rcl;
 float chordarray[rcl];
 1 => chordarray[0];
 for( 1 => int i; i <rcl> chordarray[i];
 fun void addnote (float note)
     for( 0 => int i; i <rcl> chordarray[i];
                 break;
 fun void addnotes(float note[])
     for(0 => int i; i <note> int i;
     while(i <rcl> dac;
      chordarray[i] => s.sfreq;
      <<<"adding " + chordarray[i]>>>;
      i++;
     notedur => now;
     <<<"done">>>;
ratiochord rc;
rc.addnote(1.5);
rc.test_play(2::second);
//[chuck](VM): sporking incoming shred: 1 (ratiochord)...
//"adding 1.0000" : (string)
//"adding 1.5000" : (string)
//"done" : (string)
ratiochord rc2;
rc2.addnotes([1.5,1.75]);
rc2.test_play(2::second);
// outputs:
//"adding 1.7500" : (string)
//"done" : (string)
makeitgofaster
PostPosted: Wed Jul 01, 2015 7:38 pm    Post subject: just.. really stupid Reply with quote  Mark this post and the followings unread
But then that's writing code in a new language for you.
1) I had not multiplied my array of notes by a baseline value. It was playing sounds at 1, 1.5, and 1.75 hz instead of those three factors multiplied by 220hz or something sensible.
2) When writing test code, I was also surprised to find that this first one causes a segmentation fault:
[1.0,1.5,1.75] @=> float chordarray[3];
... but this is correct:
[1.0,1.5,1.75] @=> float chordarray[];
PostPosted: Thu Jul 02, 2015 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome makeitgofaster!
Glad to see that you fixed your problem - we're a bit slow here sometimes.
As you noticed ChucK isn't completely bug-free, and the responses when you do something that ChucK doesn't expect (like reference assigning to an already initialized array) can be less than helpful. NullPointerExceptions aren't unheard of either.
A tip if you post code again - check "Disable HTML in this post" and "Disable Smilies in this post" - if you check your post you will see that some usage of less than mangled things a bit.
If you run into stuff in the future, a tip is to post a question to the ChucK users mailing list:
https://lists.cs.princeton.edu/mailman/listinfo/chuck-users
..chances are you will get a quick and useful response there, some of the guys who make ChucK read that list too. If you post your segmentation fault example there I think it may be well received. Smile
makeitgofaster
PostPosted: Thu Jul 02, 2015 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Got it! Thanks. Smile
