Does the FluidSynth Chugin work?
Page 1 of 1 [4 Posts]
brkl
PostPosted: Sun Sep 06, 2015 12:39 am    Post subject: Does the FluidSynth Chugin work? Reply with quote  Mark this post and the followings unread
Hi! The Chugin info ( http://chuck.stanford.edu/extend/#chugins ) mentions a FluidSynth implementation that should be compiled into new versions of ChucK. Mine does not include this and I've been unable to compile it from the sources available online ( https://github.com/spencersalazar/fluidsynth.chug and https://github.com/ccrma/chugins/tree/master/FluidSynth). Does a working FluidSynth Chugin exist and where could I get the binaries since I'm not experienced enough to get it compiled from source? I'm running Windows if that makes a difference.
Thanks for the help!
Phloxs
PostPosted: Fri Oct 02, 2015 12:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi! How did you install this libriary?
brkl
PostPosted: Fri Oct 02, 2015 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
I couldn't. That's the whole point of the post. I've spent at least 20 hours trying to get it to work. I've even been able to compile the file, but there's some problem with it because I get an error each time I load chuck (chuck_dl error 126). It doesn't work. I'd love to have it.
Phloxs
PostPosted: Mon Oct 05, 2015 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you install all dependencies?
