voice mix levels
Page 1 of 1 [2 Posts]
happyham
PostPosted: Sun Oct 04, 2015 3:53 am    Post subject: voice mix levels Reply with quote  Mark this post and the followings unread
One of the best tips from tips and tricks was to lower the amp envelope level to under 80 percent. It makes a huge difference in clearing up the sound. Before I had paid attention to pre and post filter levels, but I had overlooked this, and I wouldn't be surprised if not knowing it is the reason why some experience synth users end up not liking the andromeda. It's also made me wonder if there is a similar effect with the voice mix levels, I've tried lowering them to under 80 percent, and think it's also cleared up the sound. I couldn't find anything about this in tips and tricks and elsewhere. Has anyone else noticed this or am I losing my marbles?
Pollux
PostPosted: Sun Aug 07, 2016 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've heard this mentioned a lot, on forums and in the Andromeda Tips and Tricks (to keep the Amp / Levels underneath a certain amount, or else the waveforms get distorted) --- so I hooked my Randy Andy w/ only Osc 1 Sine Wave enabled, up to an Oscilloscope, and indeed, whenever any "Filter Mix" level is above 30 I noticed distortion (ofcourse this is desirable for certain sounds).
i.e. When only Osc 1 is enabled, with a Sine wave and Filter Mix Osc 1 level Is under 30, It's a perfect sine wave. When I increased the Osc 1 Filter Mix above 30, I could see the sine wave getting SLIIGHTTTLYYYYYY more squarish. I did not notice any distortion when experimenting with Voice Level or Master Out. It seems "Filter Mix" levels are the one's to keep an eye on -- keep any value below 30 to keep the waveform 'pure'
I can post pics later
Checkout my Alesis Andromeda A6 Editor, etc, @ my Website
