waveshaper used as VCA for rectangle waveforms
gabbagabi
PostPosted: Fri Jan 08, 2016 12:59 pm    Post subject: waveshaper used as VCA for rectangle waveforms Reply with quote  Mark this post and the followings unread
Hello,
by accident i came across a additional use for the SAW/TRI waveshaper.
If you feed a envelope (or Lfo) in the input where normally the signal goes in, and a rectangle wave in the (dont have a name for it) other input - you can use this circuit as a VCA.
Envelope/LFO should be positive only, if not it has may same "sounding" side effects.
cheers
gabbagabi
 Filesize:  37.11 KB
 Viewed:  294 Time(s)
 Filesize:  23.29 KB
 Viewed:  231 Time(s)
