VCA Not working (NOOB)
Page 1 of 1 [4 Posts]
cchinchole
PostPosted: Mon Feb 08, 2016 7:59 pm    Post subject: VCA Not working (NOOB) Reply with quote  Mark this post and the followings unread
I'm a noob at synthesizers so please don't be too harsh.
I built Thomas Henry's vca-1 and the cv works fine ,but I don't get sound (frequency) when I press a key just a click from the gate.
From my understanding if I plug a gate signal into cv and a frequency into the audio input it will produce a sound only when I press a key on my keyboard.
My current setup:
Gate from my controller -> cv input
Frequency generator -> audio input
Anonymous301
PostPosted: Fri Mar 25, 2016 6:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi cchinchole,
You should use an ADSR-Envelope-Gen. Then your setup seems like this:
VCA <- (out)ADSR(gate input) <- Gate
VCO or other audio source
Very Happy.
Greetings Ano
Audio files: 640
PostPosted: Fri Mar 25, 2016 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Using an ADSR is the most common way but it should still work with just a gate signal. Unless it is only a short trigger pulse.
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider
DES
PostPosted: Sat Mar 26, 2016 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Its possible that the gate signal is not high enough to fully open the VCA. I believe most gate signals on relatively new gear is 5vdc but the VCA may require a higher voltage...say 10vdc. Depending on whether its a log or linear response VCA could determine whether you hear anything or not.
Does your VCA have a gain control? If so try turning it up to see if any audio comes thru.
www.davesneed.com
