 Forum index » Instruments and Equipment » Cwejman Sound
Cwejman RES-4 individual outputs mod
Page 1 of 1 [2 Posts]
macumbista
PostPosted: Thu Feb 18, 2016 8:55 am    Post subject: Cwejman RES-4 individual outputs mod Reply with quote  Mark this post and the followings unread
Dear EM people,
[EDIT: changed deadline to 15 MAR 2016, added individual attenuators to the breakout panel, changed breakout panel size to accommodate the attenuators 22 FEB 2016].
last year, a client of mine wanted individual outputs for each filter in his RES-4, so I brought those and the power bus to the breakout cable. Several other people over at Muff's asked me if I could make a similar modification to their RES-4s as well. You can see the original thread here:
https://www.muffwiggler.com/forum/topic-146237.html
I finally decided to do a "group-mod" deal for everyone who asked, and I wanted to extend the offer here as well.
I am currently taking reservations to do this modification at my studio in Berlin. The modification will include the following:
1) Four independent outputs from the RES-4 sent to daughter board
2) Four buffered outputs to minijacks on the daughter board
3) Four attenuators to control the individual filter outputs of the daughter board
3) One CNC-milled anodized alu front panel 8HP / 40.3 mm (same as Doepfer mixer A-138 Mixer)
As the filters will be tapped before the VCAs, the attenuators on the RES-4 will still control individual filter volumes at the main mix output of the module. In fact, the RES-4 will work precisely as it did before the mod, whether the daughter board is connected or not. The daughter board will be powered from the PCB of the RES-4, as seen in the photos at the start of the Muff's thread
Unfortunately, I cannot show you the breakout panel at this time, but I can show you examples of my work doing CNCed Benjolin panels here:
http://macumbista.net/?p=4539
Please contact me by email at MACUMBISTA at the domain GMAIL dot COM, using the subject line RES-4 MOD to get my attention Wink
The price would be EUR 60 (incl 19% VAT) / EUR 50 (shipped outside EU, or shipped outside Germany with valid EU VAT number) plus shipping costs.
Non-EU people, keep in mind you will be liable for any customs duties *in both directions*, so get in touch if this applies to you and I will see what we can work out.
I will mill the panels on 15 MARCH, so I would ask a 50% deposit by that time. Orders will be closed after that date.
Thanks for your kind attention!
Derek
macumbista.net
macumbista
PostPosted: Mon Feb 22, 2016 2:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
My first RES-4 mod client has called to my attention that the mod I did for him was before the VCAs, so in order to control the levels of each filter an attenuator will be necessary on the breakout panel.
Also, due to some unforeseen travel, I am rolling back the deadline to send the modules to me one extra week. New deadline will be 15 MARCH.
I have updated the top post in this thread shortly to reflect these changes, as well as contacting those of you who have already reserved your place in this run. Thanks for you kind attention! D.
macumbista.net
