Nord Rack / Lead 1 Prophet 5 programs
Page 1 of 1 [4 Posts]
rysongs
PostPosted: Sun Feb 21, 2016 8:15 am    Post subject: Nord Rack / Lead 1 Prophet 5 programs Reply with quote  Mark this post and the followings unread
Hi
I notice a certain range of performance banks features recreations of the factory prophet 5 sounds, spread out over banks A-D
The question is how do we hear only one sound at a time, do you need to switch all slots to midi channel Off, then turn on to e.g channel 1 to hear it, then switch it back off, go to slot B, change to channel 1, then off before repeating with slot C and D??
Is there a shortcut we can press to 'solo' a Slot?
Eg. I choose the first performance containing prophet 5 sounds, I want to go through hearing each program but I can only hear the slot which I'm sending midi note data to. I don't want to hear all 4 slots simultaneously, I want it to be like I'm sat in front of a prophet 5 hearing one patch / program at a time.
Thanks
Ryan
Audio files: 401
PostPosted: Sun Feb 21, 2016 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I assume you have a rack version...
So press and hold shift and press MIDI, then let go and press MIDI again. You can now change the global channel, set it to anything other than any of the slots, and your keyboard controller too of course.
Now when you select a single slot you should hear only that slot.
I hope that works, I have the keyboard but i know MIDI can be a bit confusing on the rack.
Muied Lumens Base Star
rysongs
PostPosted: Thu Feb 25, 2016 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
This sorted it, thanks very much!! It was pressing MIDI a second time to set global channel that i didn't get. Also receiving Sysex patch dumps nicely now
Ryan
Audio files: 401
PostPosted: Fri Feb 26, 2016 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Great! Smile
Enjoy the Nord Lead, it's a classic in its own sense.
