Joined: Apr 03, 2004 Posts: 24508 Location: The Netherlands, Enschede
Posted: Fri Mar 04, 2016 5:40 am Post subject:
WE HAVE A RIGHT TO KNOW
Heck .. I didn't know that song .. it's a nice one. _________________ Jan
Joined: Nov 23, 2015 Posts: 1319 Location: Netherlands
Posted: Mon Mar 07, 2016 11:49 pm Post subject:
Posted: Tue Mar 08, 2016 2:55 am Post subject:
Looks more like a pipe organ now than a musical pinball machine indeed  _________________ Jan
wackelpeter
Audio files: 10
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Tue Mar 15, 2016 8:26 am Post subject:
| PHOBoS wrote: | | hmm, although it is becoming one of the biggest things I've built so far it is a bit small for a pipe organ. But a mini pipe organ would be nice, which got me thinking; could you make one out of a bunch of recorders ?! well, of course I am not the first one with that idea and found this |
The video is nice (even though I don't understand the non-musical language being used); thanks for posting the link.
In addition, for me it helps explain something--monophony, polyphony, and the new-comer--paraphony. (Perhaps it also explains another concept; let's call it tonophony.)
Normally (and using normal playing techniques), each recorder is capable of playing one note at a time. Therefore it is monophonic. As I understand it, each pipe in a pipe organ is similarly monophonic.
However, each pipe in a pipe organ can play only one note, whereas a recorder (normally) can play different notes. Let's say the recorder is polytonophonic. That is, serially, it can play more than one note, whereas each pipe in a pipe organ is monotonophonic. That is, serially, each pipe can only play one note. (When someone speaks in a "monotone," that person doesn't "inflect"--or change pitch/vocal frequency.)
Because the pipe organ has many different pipes, it can play many different notes simultaneously. Similarly, the recorder organ can play many different notes simultaneously. So, the inventor in the video has converted polytonophonic recorders into monotonophonic recorders.
However, as collections of pipes/recorders capable of playing more than one pipe/recorder at a time, the organs are "sort of" polyphonic, but not quite.
Since each monotonophonic recorder/pipe has no individual expressiveness--i.e., no analog counterpart to VCA+VCF control on a per recorder/pipe basis, the collection (aka organ) is not by contemporary nomenclature "truly" polyphonic. Using contemporary language, however, it can be called "paraphonic."
Of course, in the hands (or rather the mouth) of a human, a normal recorder "sort of" has expressiveness, so a single recorder being played by a single human can be called a polytonophonic monophonic quasiphonic instrument. In the hands of a human, a normal pipe organ has expressive controls globally over collections of pipes (i.e., subsets of all the pipes) and can be called a polytonophonic paraphonic quasiphonic instrument.
Of course, there are also recorder ensembles that could have collective control over the full sound produced by the ensemble with each musician affecting the expressiveness of each individual recorder. Thus, we can say that such an ensemble (as a whole) is indeed polyphonic--but only to the degree each musician can control the analog counterpart to VCA+VCF.
Similarly, a mouth organ can be said to be a polytonophonic paraphonic quasiphonic instrument, and a mouth organ ensemble can be called polyphonic in the same sense that a recorder ensemble can.
Again, nice video; thanks for posting. At last I join the ranks of those who find distinguishing between "paraphony" and "polyphony" useful.
Steve |
Posted: Tue Mar 15, 2016 3:31 pm Post subject:
hmm after reading that I think my synth is quasiparatonophobosonic..
131.81 KB |
| Viewed: |
652 Time(s) |
136.39 KB |
| Viewed: |
619 Time(s) |
Posted: Tue Mar 15, 2016 3:49 pm Post subject:
How about multiphonics?
There seems to be plenty power for that  _________________ Jan
Posted: Mon Mar 21, 2016 1:57 am Post subject:
| Nice colorful fronts! |
Posted: Sun Mar 27, 2016 2:16 pm Post subject:
I found a nice way to attach the PSU and make it removable for wiring.
109.72 KB |
| Viewed: |
640 Time(s) |
126.35 KB |
| Viewed: |
601 Time(s) |
110.01 KB |
| Viewed: |
622 Time(s) |
Joined: Jan 15, 2011 Posts: 429 Location: Montreal, Canada
Posted: Mon Mar 28, 2016 10:15 am Post subject:
| PHOBoS wrote: | | hmm after reading that I think my synth is quasiparatonophobosonic.. |
How about just PHOBoPHOniC?
.:James:. |
Posted: Fri Apr 08, 2016 2:49 pm Post subject:
Hmm .. what is that red guillotine good for I wonder  _________________ Jan
Cfish
Posted: Sun Apr 17, 2016 7:31 pm Post subject:
My bet is on MIDI controlled glockenspiel.
But I'm not betting more than a dollar. |
Posted: Mon Apr 18, 2016 1:49 pm Post subject:
I soldered some more of the electronics so here are some pictures of it. Also finally put the sides on so I have to do more painting.
Which is a rather slow process because I have to wait between layers and I can only do small parts at a time due to space constraints.
And than there is the thing where I have to tape of parts when using a different color and sometimes paint creeps underneath
or it comes off when I remove the tape. (I should probably sand and clean a bit better).
oh and no, it is not going to be a MIDI controlled glockenspiel.
226.55 KB |
| Viewed: |
614 Time(s) |
254.82 KB |
| Viewed: |
645 Time(s) |
235.67 KB |
| Viewed: |
616 Time(s) |
251.78 KB |
| Viewed: |
660 Time(s) |
Posted: Mon Apr 18, 2016 1:58 pm Post subject:
Ah! Steve must have been right then in a way I guess, with the multi stuff he brought up .. seeing a lot of repetition!
The suspense is killing  _________________ Jan
