basic volt per octave keyboard schematics
Page 7 of 7 [162 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7
Audio files: 29
PostPosted: Sat Nov 19, 2016 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
One of my favo sites when it comes to calculation of schematics behavoural calculations is THIS site.
Audio files: 644
PostPosted: Sat Nov 19, 2016 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I have also a bunch of zener diodes of many values.Which do i pick and how do i connect it?
You need a 10.0V zenerdiode and a resistor, 1K will probably do but you could experiment a little. Connect the cathode of the zenerdiode
to GND, the anode to the resistor and the other side of the resistor to -12V. The point where the diode and resistor are connected will be
your -10V reference voltage.
Now,looking for a definitive solution.I only have LM 317,(positive regulator), but not the LM 337 which will do the job from what i've heard.
That actually made me think of another method last night but it is a bit over the top for this purpose. Use the LM317 to create a +10v
voltage and then use an opamp configured as a inverting amplifier with a gain of x1 to invert it to -10V.
Cfish
PostPosted: Sat Nov 19, 2016 5:18 am    Post subject: Reply with quote  Mark this post and the followings unread
extremly useful link grumble.
Edit. That would be a great link in the (fun useful tips thread)
alanwilder81
PostPosted: Sat Nov 19, 2016 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Grumble Smile
designing and calculating things for now is a bit over my head, but this site will come handy in the future
to Phobos,
i've come across a website where they describe the inverting opamp method you mention to change the voltage polarity,Now you confirm it works.
I will also try the zener diodes thing.Good to know different approaches to get this matter around Smile
alanwilder81
PostPosted: Sat Nov 19, 2016 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
to Cfish
i can confirm that the keyboard circuits works decently.The VCO i used for testing it tracks ok.It s only three octaves but hey. Enough for a little monophonic analog synth.
Audio files: 29
PostPosted: Sat Nov 19, 2016 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
But why do you want -10volt? you could just as easily put a resistor of 10k in series with the potmeter of 1k and connect it with the -12volt.
This resistor will prevent the -input of the opamp being directly connected to -12volt if you happen to turn the potmeter to 0 ohm.
Usualy opamps dislike to have the inputs connected to the power supply (pos. nor neg.) and the resistor prevents that from happening.
It may not be very stable, but you can play anyways.
alanwilder81
PostPosted: Sun Nov 20, 2016 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
i want -10 V because in the schematics its specified so
Audio files: 29
PostPosted: Sun Nov 20, 2016 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
There is no law against changing diagrams to ones likings, in fact it realy helps you in understanding whats going on...
alanwilder81
PostPosted: Sun Nov 20, 2016 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
tweaking diagrams is well over my head.So,for the moment i'm settling for working with what's there and trying to wrap my head around that. Cool Cool
alanwilder81
PostPosted: Sun Nov 20, 2016 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
to Phobos,
excellent trick, i got my steady -10 V reference voltage Smile
Cfish
PostPosted: Sun Dec 04, 2016 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, experimenting with the yousynth schematic on here has led me to try to add basic trigger to the original schematic that has grown along the way.
Looks like it should work
 Filesize:  702.86 KB
 Viewed:  377 Time(s)
 Filesize:  959.25 KB
 Viewed:  414 Time(s)
Cfish
PostPosted: Sun Feb 16, 2020 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I’m still using that final schematic of this in my key pedals, never could get it to tune right for more that 3 octaves, but it’s great for what I use it for now.
 Filesize:  1.12 MB
 Viewed:  8 Time(s)
