Audio files: 278
Posted: Sun Jun 05, 2016 3:47 pm Post subject:
The idea is that you should be able to do whatever suits you best there ... both ways should work. Oh and re. miditangle vs. NetMidi, they should act the same.
One other thing is that CC mapped controls will not send CC values when the mapped control is changed in the editor (with mouse or keyboard), they can only listen. I could change that I guess at some stage. _________________ Jan
Joined: Aug 08, 2009 Posts: 1082 Location: Out scouting . . .
Posted: Sun Jun 05, 2016 5:58 pm Post subject:
Blue Hell wrote: | . . . CC mapped controls will not send CC values when the mapped control is changed in the editor (with mouse or keyboard), they can only listen. I could change that I guess at some stage. | I have not gotten to generate midi values (notes or CCs) to send outside of wren. I did try to have wren send midi notes to another softsynth, but I didn't figure out how to set it up properly. Maybe another time. |
Posted: Mon Jun 06, 2016 5:28 am Post subject:
Blue Hell wrote: | Any incoming MIDI is assembled into proper messages, taking running status into account.
Then the message is sent into the patch where any special MIDI modules get a chance to pick it up according to the message content and the settings for that module. | I will assume this means the modules like CCMidiIn and NoteMidiIn.
Blue Hell wrote: | Then when the message is a MIDI CC message and the receive channel for Wren matches the message's channel | I will assume this refers to the global CC assignments that currently use the midi channel as assigned in Settings/NetMidi-MidiTangle.
Blue Hell wrote: | (or when Wren is set to receive in OMNI mode, meaning it processes all channels) a possibly matching CC to knob assignment is being processed. For this the whole CC range of 0 to 127 is mapped onto the actual number of knob positions available. | Again, I will assume this refers to the global CC assignments.*
Steve
*Addendum 1:
The value module (see screen shot I posted showing 16 CC knobs coming from the nanoKontrol) does indeed display 0 to 127. In addition, when the CC is globally mapped to the freq. knob in the osc., a midi value of 0 corresponds with the lowest possible freq value so far as I tested and a midi value of 127 corresponds to the highest possible frequency value. Last edited by MusicMan11712 on Mon Jun 06, 2016 12:01 pm; edited 1 time in total |
Audio files: 278
Posted: Mon Jun 06, 2016 10:31 am Post subject:
A channel for MIDI CC's .. hmm .. you really need more than 120? _________________ Jan
lamptablecomputer
Posted: Wed Jun 08, 2016 11:04 am Post subject:
Thanks for fixing the midi cc problem Jan! |
Audio files: 278
Posted: Wed Jun 08, 2016 11:10 am Post subject:
You're welcome - please let me know about other issues ... I'm still finding some myself as well. _________________ Jan
