Fun useful tips
Page 4 of 4 [87 Posts]
Audio files: 35
PostPosted: Fri Jun 09, 2017 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cfish wrote:
Anouther good practice with mains power is after insuring the power is off with a meter, turn your eyes away and short it with an insulated screwdriver.
When working with valve amps, it's a good idea to solder up a 2W bleeder resistor with alligator clips wired to each end. (I vaguely remember that just shorting it all the time is not good for some component, but I don't recall what.)
Make a habit of the first thing you do when the amp is showing it's guts, is to clip one end of the bleeder onto ground, and the other end onto the HT node, and leave it there until you want to power it up for testing.
gabbagabi
PostPosted: Sun Aug 13, 2017 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
i recently found out that staples are an endless source of bridges for breadboard action,
watch out for coated staples they are not conducting
Audio files: 624
PostPosted: Sun Sep 17, 2017 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
when you drill a hole in a plastic enclosure with a 0.7mm drill bit
don't put your finger behind it.
(also made this thread a sticky)
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider
gabbagabi
PostPosted: Sat Dec 23, 2017 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
if u are in the situation of
spending christmas soldering on a remote island
with no elecrtonicshop on spot -
and ur soldertip has gone
to where all soldertips will go one day -
a piece of fix copper wire will do the job
until the next ship will bring u home.
tested with 2,5mm².
santa
happy smoker
xxsun
gasboss775
PostPosted: Sat Dec 23, 2017 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
tested with 2,5mm².
santa
happy smoker
xxsun
Sounds like the kind of thing I'd have done when I was 15, just to see if it would work! What did you use to power your DIY soldering iron?
gasboss775
PostPosted: Sat Dec 23, 2017 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Probably an obvious tip, but some have said I lack common sense...
When soldering onto a PCB or onto a pot or jack, etc make sure the object is secure prior to commencing soldering, otherwise the result could be quite messy
gabbagabi
PostPosted: Sun Dec 24, 2017 1:20 am    Post subject: Reply with quote  Mark this post and the followings unread
no no!
only the tip!
only!
the rest should be prefabricated!
otherwise u risc to feel like him
Cfish
PostPosted: Sun Dec 24, 2017 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I have not been on in a while. Ya all have no idea how good it made me feel to see people still posting on this thread.
Merry Christmas everyone.
Audio files: 624
PostPosted: Sun Dec 24, 2017 9:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Happy holidays to all my fellow DIY folk! santa
gasboss775
PostPosted: Mon Dec 25, 2017 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Seasons greetings all!
santa rendeer santa rendeer santa
party time!
gabbagabi
PostPosted: Mon Dec 25, 2017 11:46 am    Post subject: Reply with quote  Mark this post and the followings unread
merry christmas from summerrainy africa @25°
afro santa happy smoker love
gabbagabi
PostPosted: Wed Jan 17, 2018 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
how to make pcb with Lochmaster
means u could make a stripboarddesign same time a pcb
 Filesize:  137.32 KB
 Viewed:  272 Time(s)
 Filesize:  161.21 KB
 Viewed:  269 Time(s)
 Filesize:  117.42 KB
 Viewed:  273 Time(s)
