Editor Tips: Small windows out of the screen
Page 1 of 1 [2 Posts]
gauthier
PostPosted: Sat Dec 17, 2016 7:05 am    Post subject:  Editor Tips: Small windows out of the screen Reply with quote  Mark this post and the followings unread
I use my laptop on different screens with varying resolution, the editor remembers the position of small windows but won't check if they appear on the screen.
That make those windows out of reach when you change resolution, to fix that issue you need to do:
* delete the .pref file in C:\Users\your user name\Application Data\Clavia\
* delete the HKEY_CURRENT_USER\Software\Clavia\Nord Modular G2 Editor key in registry
on next restart all the preferences will be reset (it will reinitialize other settings of the editor so beware).
Audio files: 231
G2 patch files: 319
PostPosted: Sat Dec 17, 2016 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
The .pref file for win8 on my laptop is in
C:\Users\your user name\AppData\Roaming\Clavia\
And I have never needed to delete stuff from the registry. Just terminate the editor, remove the file and restart the editor.
AppData may be a hidden folder, but 'Application Data' (which is a shortcut) allows me no access.
Oh, and you may have two .pref files, one for the editor and one for the demo.
I've stickied this post as the question comes up every so often.
