CGS 29 build need help!!
michel07
PostPosted: Wed Jan 04, 2017 6:04 am    Post subject: CGS 29 build need help!! Reply with quote  Mark this post and the followings unread
Hi there,
I've finished to build a CGS29 wave multiplier from ken stone.
The module works quite well but I've got a hiss problem (white noise plus a kind of pulse) that happens at certains level of offset and fold modulation (manually or by CV). I checked values of all components, bad ground traces, everything I can but whithout result. I'd like to know if there is a debug process for this module because I don't understand how it works and where I should search. I can mesure voltages at some points if someone tell me where.
Thanks a lot.
