NoodleDriver
Posted: Thu Feb 09, 2017 8:11 am Post subject:
Both of you are my eletronic heroes!
Description: |
Filesize: |
3.1 MB |
Viewed: |
495 Time(s) |
Description: |
Filesize: |
4.18 MB |
Viewed: |
559 Time(s) |
Description: |
Filesize: |
3.68 MB |
Viewed: |
507 Time(s) |
Audio files: 705
NoodleDriver
Posted: Thu Feb 09, 2017 9:38 am Post subject:
Thank you kindly sir.
Yes, that's a resistor in a ménage à trois with a pair of trannies hinding under the foam. |
Audio files: 705
LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Fri Feb 10, 2017 1:12 pm Post subject:
Nifty way to mount the pcb, did you just glue that or is there something like interlocking features? |
Cfish
Posted: Fri Feb 10, 2017 7:44 pm Post subject:
Awesome attention to detaile noodle |
NoodleDriver
Posted: Sat Feb 11, 2017 12:51 am Post subject:
Thanks guys,
Yes, both. I milled a tenon out of the back of the face plate where the bracket and struts attach then epoxied it all together. An average panel takes about 10 mins to cut on the CNC router. The PCB in this pic took about 20 mins to cut (while I was drinking beer in the other room) |
Joined: Jan 07, 2009 Posts: 1196 Location: Scottish Borders
Audio files: 155
Posted: Thu Feb 16, 2017 1:13 pm Post subject:
Nice build noodle , great way of mounting the board with the tenon
Dave. |
fuji
Posted: Wed Mar 08, 2017 3:57 am Post subject:
my first diy synth built with many modules:
cv sequencers, gate sequences, gate to trig conv., lm358 vcos, 40106 xor drum noises, dividers, lm358 vcas, 2n3904 passive vcas, passive mixer, tl071 sallen-key filter and a 4094 16bit shift register, using single rail 9v
Description: |
Filesize: |
100.96 KB |
Viewed: |
442 Time(s) |
Description: |
Filesize: |
71.54 KB |
Viewed: |
439 Time(s) |
Description: |
Filesize: |
65.55 KB |
Viewed: |
414 Time(s) |
Audio files: 278
Posted: Wed Mar 08, 2017 11:55 am Post subject:
fuji wrote: | my first diy synth built with many modules |
looks nice
When you have any sound samples from it - please post some as an attachment here _________________ Jan
fuji
Posted: Wed Mar 08, 2017 4:01 pm Post subject:
Blue Hell wrote: | fuji wrote: | my first diy synth built with many modules |
looks nice
When you have any sound samples from it - please post some as an attachment here |
Yes! Here is a recording i made some days ago (it was a little bit different - only one vco and other things was missing)
https://soundcloud.com/frgm/modular-synth |
Audio files: 278
Posted: Thu Mar 09, 2017 2:55 am Post subject:
Sorry, soundcloud needs flash, and I can not use that. _________________ Jan
fuji
Audio files: 278
Posted: Wed Mar 29, 2017 4:29 am Post subject:
fuji wrote: | Blue Hell wrote: | Sorry, soundcloud needs flash, and I can not use that. |
hi! i added it as attachment! btw sorry for late! |
Thanks! sounds good :-) _________________ Jan
prgdeltablues
Audio files: 12
Posted: Wed Mar 29, 2017 6:08 am Post subject:
Latest addition: MFOS four pole (24dB/Oct) VCF. Modded to include HP, BP, and Notch outputs in both four pole and two pole flavours. Also modded to include a shruthi/jupiter enhancement to the resonance loop that reduces the output drop as resonance increases, and boosts the higher frequencies.
Had a lot of difficulty with the self-oscillation - had to change several resistor values, and it still doesn't oscillate easily below about 700Hz (depends on the temperature!). No idea why that is.
Peter
Description: |
Filesize: |
1.75 MB |
Viewed: |
274 Time(s) |
Description: |
Filesize: |
1.98 MB |
Viewed: |
310 Time(s) |
roglok
Posted: Thu Mar 30, 2017 12:49 am Post subject:
fuji wrote: | my first diy synth built with many modules:
cv sequencers, gate sequences, gate to trig conv., lm358 vcos, 40106 xor drum noises, dividers, lm358 vcas, 2n3904 passive vcas, passive mixer, tl071 sallen-key filter and a 4094 16bit shift register, using single rail 9v |
looks great. how's the workflow with crocodile clips? was that a budget decision? |
fuji
Posted: Fri Mar 31, 2017 2:35 am Post subject:
roglok wrote: | fuji wrote: | my first diy synth built with many modules:
yes it was a budget decision, but i think it is also more fast in the building and in the playing phase |
Posted: Sun Apr 02, 2017 8:28 pm Post subject:
It feels good to get a build done this year!
Some issues with this -- the feedback pot works backwards (CV in, OTOH, works normally), and two pins on the THAT2181 needed swapping.
Otherwise, this is a very nice delay. Based on Ryan Williams' schematic for the PT2395. |
Posted: Mon Apr 03, 2017 10:28 pm Post subject:
Seems to go good to me, this thing makes insane sounds.
Good news is that Bei Ling BL3207 and BL3102 clone chips work nicely (if at a low frequency range, don't expect to piss off the dog.) I still have to calibrate the V/Oct.
Good stuff, though! |
LFLab
Posted: Tue Apr 04, 2017 6:22 am Post subject:
Nice one Alan!
Any clock osc whine?
Still want to do a euro layout for the Blacet Time machine, that has clock controlled 5th order lowpass filters, seems like a very good idea. |
Audio files: 705
Posted: Wed Apr 05, 2017 6:18 am Post subject:
nice modules alan, I like the color schema of the Karplus Strong one.
I wonder where you got the toggle switches as I have recently designed
some PCBs that use them but the switches I have seem to be just a tad
to high to use in combination with Thonkiconn jacks and yours seem to
leave enough space to even add a nut. _________________ "My perf, it's full of holes!"
Posted: Wed Apr 05, 2017 10:39 am Post subject:
For the switch, it's just a Tayda on-off-on.
No clock bleed that I can hear. |
Audio files: 705
Joined: Jan 15, 2011 Posts: 427 Location: Montreal, Canada
Posted: Thu Apr 20, 2017 2:01 pm Post subject:
The Bag Balm Box is "for bunches, caked bags, cuts, sore teats, chapping and inflammation". Bag Balm is a salve developed over 110 years ago to soothe irritation on cows' udders after milking but also used by humans for dry, chapped skin. I loved the container artwork, so after finally finishing the contents (which took several years), I decided to put in a little sound-making circuit, which is a slightly tweaked version of the Space4069 schematic by Synaesthesia. It uses CMOS 4069 to generate waveforms which feed a 4046 VCO. See thread http://electro-music.com/forum/topic-63269.html .
Two potentiometers on the left control the oscillator rates, two 3-position switches on each side to control the wave shapes of each (sawtooth, triangle, reverse sawtooth), plus frequency and volume controls. On the back, the on/off switch, the range switch (high, low), and the output jack. Through the eye of the cow, a white LED indicates that the power is on (9V battery).
I was thinking of somehow making some knobs that looked like cow udders, but got lazy because I have many other projects on the pile.
Here is the Bag Balm Box demo video: https://youtu.be/DrY-9-HWl7A
.:James:.
Description: |
The Bag Balm Box in the grass. |
Filesize: |
302.85 KB |
Viewed: |
277 Time(s) |
