AmMod
Page 1 of 1 [3 Posts]
Wobble
PostPosted: Sun Feb 12, 2017 10:38 pm    Post subject: AmMod
Subject description: Question on its use
I have a sinus signal feed into a rectifier with "full wave".
I use that to control the amplitude modulation in an AmMod.
The AmMod mod amount is set to 1 and offset to 0, and no ring.
Still when the input absolute sinus from the rectifier is zero, I don't get zero output. Its like its still offset by some. (looked at the output in Audacity)
I verified that the rectifier outputs as I want, and it does, so its the AmMod that does not output what I want.
In this picture can be seen at top the sound I want to make, and below it the output from the attached patch:
Any suggestions on what I am doing wrong?
AmMod.wren
This is the simple setup I have.
 Filename:  AmMod.wren
 Filesize:  4.76 KB
 Downloaded:  727 Time(s)
Audio files: 278
PostPosted: Mon Feb 13, 2017 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
The signal type for the mod input is set to bipolar while you are using an unipolar input signal. This is the triangle near the mod input.
Wobble
PostPosted: Mon Feb 13, 2017 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
did the trick, thank you.
