Playing MIDI notes
Page 1 of 1 [3 Posts]
Wobble
PostPosted: Mon Feb 13, 2017 10:49 pm    Post subject: Playing MIDI notes
Subject description: How to?
How do I make a sequencer play MIDI notes? Specifically drums.
And I would like to not use the windows midi mapper device, as it sounds horrible. I have a nice creative card loaded up with a nice SoundFont.
Don't really know how else to get drum sounds into Wren without using the Waveplayer.
Edit: I figured out how to send notes to NetMidi, is there way to control netmidi's volume?
Audio files: 243
G2 patch files: 319
PostPosted: Tue Feb 14, 2017 6:12 am    Post subject: Reply with quote  Mark this post and the followings unread
The midi note output module has a velocity input which should control the level of the notes. When you want to send MIDI volume you'd want to send CC 7 commands. NetMIDI is totally transparent and changes nothing in the MIDI stream.
Wobble
PostPosted: Tue Feb 14, 2017 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Works like a charm, thanks!
