  PHOBoS presents: music from project "droning" by Lougi Verona
Need help with OTA based VCA
Page 1 of 1 [10 Posts]
acidblue
PostPosted: Tue Apr 04, 2017 11:53 am    Post subject: Need help with OTA based VCA Reply with quote  Mark this post and the followings unread
I have the following VCA schem on bread board.
But it's not working as expected, I'm getting a constant 13V from the output, but no sound.
I changed the divider on the input to R1 - 47k and R2 -100R in order to get below 20mV, the default values gave me the same result, thought that might have been the problem, my original input was around 59mV.
I have a slow LFO, roughly swinging between +5 and -4 volts on the CV input.
Using a 2n3904 for the transisor
Everything is running on +15,-15 from same supply.
Voltages:
input from 40106VCO 6.3V
Pin 3 CA3080: 15mV
Pin 6(741) Output steady 13V
3904 collector(3) 0.7mV
3904 Base(2) 640mV
3904 Emitter(1) swings -50 to -75mV
Seems to me that the NPN transistor should be a PNP, but what do I know.
Any insight would be appreciated.
 Filesize:  79.88 KB
 Viewed:  240 Time(s)
gdavis
PostPosted: Tue Apr 04, 2017 5:33 pm    Post subject: Re: Need help with OTA based VCA Reply with quote  Mark this post and the followings unread
acidblue wrote:
I changed the divider on the input to R1 - 47k and R2 -100R in order to get below 20mV...
sounds good.
Voltages:
Pin 3 CA3080: 15mV
40106VCO, so these should be oscillating signals? Give them as a swing like you did for the LFO, not just DC values which is ambiguous.
Usually means the opamp isn't connected correctly (or possibly bad IC). Check pins 2 and 3 on IC2. Pins 2, 3 and 6 should all show almost exactly the same signal voltage. Also make sure V+ and V- pins are correct.
I would expect this to be closer to 0V (same as pin 2 and 3 on IC3 which should also be 0V)
3904 Base(2) 640mV
The emitter should swing from about -13.6V (when Vin control is 0V) to -8.6V (when Vin Control is +5V).
The base should be about .7V above the emitter when Vin Control is positive (so swinging between -12.9V and -7.9 relative to ground). Not sure what will happen when Vin Control is negative. I'll Have to mull over that one.
NPN is fine. Edit: It should be a PNP.
Double check all your connections and make sure that points that are supposed to be connected together actually are connected (have the same voltage). Sometimes breadboards will have a bad connection.
acidblue
PostPosted: Tue Apr 04, 2017 8:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you good sir for your reply.
I have torn up this circuit and moved on to a LM13700 based VCA which works.
Some time in the foreseeable future I will have to come back to this schem ,just because I have a few CA3080 in my arsenal, and try the things you mentioned.
I'm sure it was something I had wired wrong , but staring at a circuit for an hour trying to find a mistake just wasn't working, time to move on.
gabbagabi
PostPosted: Fri May 05, 2017 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
a pic from the storage room, it is a pnp there,
i've checked also the formant vca (which also use 3080) there is also a pnp in use
 Filesize:  225.28 KB
 Viewed:  194 Time(s)
gdavis
PostPosted: Fri May 05, 2017 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
The circuit can be designed to be either PNP or NPN based, but the transistor type is not interchangeable within a given circuit. Note that the PNP based circuit needs a negative control voltage vs. the positive voltage of the OP circuit. Not sure what (if any) advantage there would be for one over the other.
Actually, I'm struggling to see how the PNP circuit above would work with the negative control voltage... Confused
gabbagabi
PostPosted: Fri May 05, 2017 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
lol never saw that Embarassed
i also guess the CV should be positive
anyway some more pnp examples
https://lh3.googleusercontent.com/-n4x88ApBp9A/VcneXrT39KI/AAAAAAAABMg/V_HaZVuPB2s/w623-h538-no/VCA_old.jpg
https://www.elektormagazine.com/assets/upload/img/partial/landscape/3080-vca.PNG
gdavis
PostPosted: Fri May 05, 2017 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ya, probably a typo, it happens.
So ya, either one can be used. PNP does seem to be more common. With NPN, I think the opamp output would have to get to within about 1.4V (or closer?) of V- which might be tough depending on the opamp. With PNP the output range can be controlled with the feedback resistor. Maybe that's why PNP is preferred.
elektrouwe
PostPosted: Sat May 06, 2017 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
uh, lot of confusion here, both pictures have errors.
The circuit that feeds the OTA is a voltage controlled current source. I'll explain it for the 1st pic. A positive (!) CV creates an input current Iin = CV/R7.
Because the OTA has a control range Iabc =0..1mA, R7 must be around 10k
for a max. CV of +10V. IC3 invertes and pulls down Q1 base. So it must be a PNP (!) with emitter connected to -in of IC3. Because the base current is about 0.5% of the collector current, 99.5% of the CV input current exit Q1 collector and drive the OTA. D1 and R6 protect the OTA in case of negative input voltage, because an OTA can easily be killed by too much Iabc.
gdavis
PostPosted: Sat May 06, 2017 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're right, NPN won't work in the OP circuit, but I'm still trying to wrap my head around exactly why.
The opamp will produce whatever voltage it needs to maintain Vin- at 0 volts. I was thinking this would be negative, yes, but that would be fine since the collector would be at 0V and the emitter would be negative and it would still produce the desired result.
After thinking about it some more, I figure the problem is that the NPN reacts in the opposite direction than we need it to. When the control voltage goes up, the opamp output wants to go down which would let less current through the NPN when we want more. In effect, the NPN connected to Vin- actually creates positive feedback rather than the desired negative feedback (2 negatives = positive). A PNP gives the opposite behavior - more negative opamp output gives more current, so connecting it to the Vin- input of the opamp gives negative feedback.
I tried a spice simulation and was a little surprised by the results. It looks like it finds a stable state which turns out to be putting a positive voltage to the NPN base, forward biasing the base-collector junction as well as the base-emitter juntion. This voltage varies with the control input voltage to maintain a constant 1.5mA emitter current output, which obviously isn't what we want.
Swapping the opamp inputs seems to work, I believe since it now produces the desired negative feedback.
acidblue
PostPosted: Sun Mar 24, 2019 8:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just to clarify.
The CA3080 turned out to be fake.
Circuit should work fine, just use a PNP, 2n3906 should be ok.
