JeEA
Posted: Fri Apr 21, 2017 8:46 am Post subject:
Need help with this Chuck program |
How does this program work?
I am using a usb hub and 2 waldorf rockets.
I know it is for 4 units, but i have made a prg for 2 units
My problem is that nothing happens. I don't know what is wrong.
// call setupOut(midi device, midi channel, true enables CC messages input)
// for all devices that receive MIDI data. Run chuck --probe to find device IDs
Rocket rockets[4];
rockets[0].setupOut(3, 1, false); // Rocket #1
rockets[1].setupOut(4, 2, true); // Rocket #2
rockets[2].setupOut(5, 3, true); // Rocket #3
rockets[3].setupOut(6, 4, true); // Rocket #4
// call setupIn(midi device, midi channel)
// for all device that send MIDI data. If you include a device that you also
// ran setupOut for here, and it sends MIDI CC data, you must set the third
// argument for it above to false.
Master master1;
master1.setupIn(3, 1); // Rocket #1
Master master2;
master2.setupIn(2, 0); // Keyboard
class Rocket {
MidiOut midiOut;
int midiDevice;
int midiChannel;
int acceptMidiCC;
-1 => int noteOn;
MidiMsg midiMsg;
fun void setupOut(int device, int channel, int acceptCC) {
device => midiDevice;
channel => midiChannel;
acceptCC => acceptMidiCC;
if (midiOut.open(device)) {
<<< "Opened MIDI output ", midiOut.name() >>>;
} else {
<<< "Couldn't open MIDI output #", device, " " >>>;
fun int sendMidi(int data1, int data2, int data3, int force) {
0 => int sendIt;
// <<< "Got msg ", data1, data2, data3, " state=", noteOn, force, sendIt >>>;
if (isNoteOn(data1, data3)) {
if (noteOn == -1 || force) {
if (noteOn > -1) {
// Send note off to prevent lingering notes on the Rocket
(data1 & 0xf0) + midiChannel => midiMsg.data1;
0x80 + noteOn => midiMsg.data2;
0 => midiMsg.data3;
midiOut.send(midiMsg);
data2 => noteOn;
1 => sendIt;
} else if (isNoteOff(data1, data3)) {
if (data2 == noteOn) {
-1 => noteOn;
1 => sendIt;
} else if (acceptMidiCC) {
1 => sendIt;
if (sendIt) {
data2 => midiMsg.data2;
data3 => midiMsg.data3;
return true;
} else {
return false;
class Master {
int midiDevice;
int midiChannel;
0 => int nextRocket;
fun void setupIn(int device, int channel) {
spork ~ listener();
fun int rocketIsMe(int rocket) {
return rockets[rocket].midiDevice == midiDevice && rockets[rocket].midiChannel == midiChannel;
fun void findRocketAndSend(int data1, int data2, int data3) {
isNoteOn(data1, data3) || isNoteOff(data1, data3) => int isNoteMessage;
0 => int midiSent;
for (0 => int i; i <rockets> int rocket;
if (!rocketIsMe(rocket) && rockets[rocket].sendMidi(data1, data2, data3, false)) {
1 => midiSent;
if (isNoteMessage) {
if (isNoteOn(data1, data2)) {
(rocket + 1) % rockets.size() => nextRocket;
break;
if (!midiSent && isNoteOn(data1, data3)) {
rockets[nextRocket].sendMidi(data1, data2, data3, true);
(nextRocket + 1) % rockets.size() => nextRocket;
fun void listener() {
MidiIn midiIn;
MidiMsg midiMsg;
if (midiIn.open(midiDevice)) {
<<< "Opened MIDI input ", midiIn.name() >>>;
} else {
<<< "Couldn't open MIDI input #" + midiDevice + " " >>>;
while (true) {
midiIn => now;
while (midiIn.recv(midiMsg)) {
// <<< "Received midi: ", midiMsg.data1, midiMsg.data2, midiMsg.data3, (midiMsg.data1 & 0x0f) >>>;
if ((midiMsg.data1 & 0x0f) == midiChannel) {
findRocketAndSend(midiMsg.data1, midiMsg.data2, midiMsg.data3);
fun int isNoteOn(int noteOnOff, int velocity) {
return (noteOnOff & 0xf0) == 0x90 && velocity > 0;
fun int isNoteOff(int noteOnOff, int velocity) {
return (noteOnOff & 0xf0) == 0x80 || (noteOnOff & 0xf0) == 0x90 && velocity == 0;
while (true) {
1::week => now;
