Getting started building CGS modules [Build Thread]
Page 4 of 4 [83 Posts]
Audio files: 35
PostPosted: Wed Nov 21, 2018 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you solder the wire links in?
Schläfer
PostPosted: Wed Nov 21, 2018 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
By wire links you mean jumpers?
if so yes i did
Schläfer
PostPosted: Thu Nov 22, 2018 2:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Btw my power source is +12/-12, but i doubt it is the problem, as i read in the cgs website it should operate fine at these voltages.
Schläfer
PostPosted: Fri Nov 23, 2018 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Everyhting working !
Of course it was some sloppy soldering from my part Rolling Eyes
Still have some problems to tune the cycle function but i'm not far anymore at least.
One more to go for the full dual function generator to be able to play with tasty feedback loops bounce
VID_20181123_163104.mp4
 Filename:  VID_20181123_163104.mp4
 Filesize:  18.46 MB
 Downloaded:  165 Time(s)
Hubaswift
PostPosted: Thu Nov 29, 2018 2:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome! Glad you got everything working! I already have enough on my plate right now, but once I've finished what I've started I think I may put together a VCS for use in my MU modular. Again, thanks for submitting the pcb layout!
Thinredline
PostPosted: Wed Jun 05, 2019 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
DUSG Working for me! Although might switch out the trimpots to diff ones, if i trim it too much i get no sound...not sure if thats a normal operation or not.
 Filesize:  2.14 MB
 Viewed:  70 Time(s)
haebbmaster
PostPosted: Wed Jun 05, 2019 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool. DUSG is fun!
Make modular synthesizers great again!
Modular Synthesizer DIY blog: http://modular.haebbmaster.de
The Bad Producer
PostPosted: Sun Jun 09, 2019 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that is normal, the trimmer kills the output if set too far either way (IIRC, at least one way for sure!) Check output on scope and trim for 0-5V as per docs... Looks good!
