today> Cancelled due to equipment failure - Sorry Chez Mosc
DIY Multichannel MIDI to CV converter, new design
Page 1 of 1 [5 Posts]
elkayem
PostPosted: Fri Dec 29, 2017 9:40 am    Post subject: DIY Multichannel MIDI to CV converter, new design Reply with quote  Mark this post and the followings unread
Hi All,
I had recently solicited and received great advice on the design of a MIDI to CV converter. The final result was a single-channel converter using a 5-pin DIN MIDI input, built directly into my synthesizer.
After building it, I realized I wanted MORE! My synthesizer has 3 VCOs after all, and wouldn't it be nice if I could drive all three independently with a sequencer app on my iPad. I finally put together what I wanted, and just uploaded the design (including a nifty 3D printed case) at:
https://github.com/elkayem/usbMIDI2CV_MC
I thought I would share the design here in case anyone else was looking for a good winter project. I'll also entertain code feature requests. This design features an OLED user interface for configuration settings, so it is quite flexible. A few more features:
  • Three channel Note CV output (88 keys, 1V/octave, MIDI channels 1-3) using a 12-bit DAC
  • Configurable note priority for each channel (Highest Note, Lowest Note, or Last Note Priority)
  • 5V Gate/Trigger outputs, where each channel can be independently configured to either output a gate (output high for entire length of time that note is on) or trigger (20 msec pulse each time a new note is initiated)
  • Velocity CV output (0 to 4V) for each channel
  • Pitch Bend CV output (0.5 +/- 0.5V), which can be configured for channel 1, 2, or 3
  • Control Change CV output (0 to 4V), which can be configured for channel 1, 2, or 3
  • OLED user interface, used for setting parameters and saving to EEPROM
Anyway, here are a few photos. Enjoy!
PostPosted: Sat Dec 30, 2017 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice built! salut
my synth
elkayem
PostPosted: Sun Dec 31, 2017 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Grumble wrote:
Nice built! salut
Thanks Grumble!!
Sheer Kahn
PostPosted: Wed Feb 28, 2018 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks man, I'm still using the first model. Looking forward to building this one, you saved me even more work. Much appreciated!
If you are taking requests for modifications/additions then I vote for more CC outs Smile . the more the merrier as far as I am concerned. Really handy if you are sequencing your synth from a DAW.
I probably won't build it for a while, got a big project on, but I will try to incorporate it. Again, big thanks for sharing your work!
elkayem
PostPosted: Thu Mar 01, 2018 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Sheer Kahn! Good tip on the extra CCs. It is useful to know how people use these out in the field. I don't anticipate doing a redesign anytime soon, but the pitch bend (if you aren't using it) could easily be modified to another CC out with a simple code change. I have extra bare PCBs if you ever do wind up building one. The PCB manufacturers like you to buy in bulk. Good thing they're cheap!
