8 Step sequencer
Page 1 of 1 [4 Posts]
petegaggs
PostPosted: Thu Jan 04, 2018 12:42 pm    Post subject: 8 Step sequencer
Subject description: a simple 8 step sequencer based on an arduino mini
Hello,
I've been working on a few arduino based projects recently, and would like to share them here.
This first one is an 8 step sequencer.
Features:
based on Arduino pro mini 5V 16MHz
I am powering it from 9V battery.
adjustable between 1-8 steps - optional, if the associated parts are left out, it will be fixed at 8 steps.
switchable note on/off for each step - again optional.
gate voltage is 5V
CV voltage is between 0V and 5V
I am using it with a soundlab mini-synth
the arduino sketch is here
https://github.com/petegaggs/8-step-sequencer
sequencer_all.pdf
schematic
 Filename:  sequencer_all.pdf
 Filesize:  58.53 KB
 Downloaded:  742 Time(s)
Veryfungi
PostPosted: Sat Mar 17, 2018 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi petegags,
I wanted to take a second to thank you for your post. It's provided inspiration for my sequencer design. I will post here when it's completed. Cool
pfzzz
PostPosted: Mon Aug 26, 2019 11:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys, keep it coming, I have checked out gizmo but want something more laid out. I like the features though. Maybe I should mix and match some of the available options
Audio files: 29
PostPosted: Tue Aug 27, 2019 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
If you are using an Arduino, why not add Midi to it?
That's what I did for my sequencers, it is a nice feature Very Happy
my synth
