<on air> Modulator ESP Adventures In Sound
Machine.add
Page 1 of 1 [2 Posts]
Sidewinder
PostPosted: Thu Mar 29, 2018 3:11 am    Post subject: Machine.add
Subject description: How to use
Hi all,
I'm a complete novice and trying to learn how to use machine.add
Say for example I had have two chuck files saved to my desktop and I want to run one, stop it. Run a second and stop it.
I'm getting "no such file or directory" when I am trying this.
Or even run the two listed below concurrently
// Connect sin oscillator a to D/A converter sound card
SinOsc a => dac;
//sets frequency of a to 300Hz
300 => a.freq;
// Allow 1 second to pass
1::second => now;
// Connect Sqr oscillator a to D/A converter sound card
SqrOsc b => dac;
//sets frequency of a to 400Hz
400 => b.freq;
// Set Gain to .5 which means half
0.1 => b.gain;
1::second => now;
flies
PostPosted: Sun Apr 08, 2018 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I would guess that the reason you're getting a file not found error is that the "working directory" for chuck isn't what you thought it was. If you provide an "absolute address" for your file, that may solve your problem.
Are you running from miniAudicle? If so, you can find and set the working directory in the text field found by edit->preferences->misc .
