Question about Using Laptop Keyboard as a Controller
Page 1 of 1 [4 Posts]
tz877398
PostPosted: Thu May 03, 2018 12:43 pm    Post subject: Question about Using Laptop Keyboard as a Controller Reply with quote  Mark this post and the followings unread
Hi everyone! It's my first time here. I'm pretty new at chuck, just started this January when I enrolled in a class that teaches it. For my final project, I'm using my laptop keyboard as a controller. (for example, when I press the Z key, a C is sounded. When I press the S key, a C# is sounded).
Here is the a simplified version of the code I am working on, with only Z and S keys involved:
Code:
SqrOsc s => dac;
0 => s.gain;
Hid hi;
HidMsg msg;
0 => int device;
if( me.args() ) me.arg(0) => Std.atoi => device;
if (!hi.openKeyboard( device ) ) me.exit();
while ( true ){
    hi => now;
    while ( hi.recv( msg ) ){
        if( msg.isButtonDown() ){
            if (msg.which == 29){//Press Z
                Std.mtof(48) => s.freq;//Play a C
                0.2 => s.gain;
            if (msg.which == 22){//Press S
                Std.mtof(49) => s.freq;//Play a C#
                0.2 => s.gain;
        if (msg.isButtonUp() ){ 0 => s.gain;//when a key goes up, silence
My big question I am trying to figure out: If I release any key my gain goes back to 0. For example, I can press Z, hold it down, press S, now with two keys held down a C# is sounding. This is how I want it. But, if I release Z, even if I am still holding down S, my gain goes back to zero. I want the C# to be sounding until I release it's corresponding key, regardless of if a different key is released. Do any of you guys have any ideas about how I can accomplish this? Thanks in advance! Smile
Audio files: 237
G2 patch files: 319
PostPosted: Thu May 03, 2018 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome,
For a school thingie eh .. okay .. a hint then :-)
Assuming that for msg.IsButtonUp there also is a msg.which identifying which key went up ... you could keep state for the keys you'd want to handle. The state could could be or could include which key was the last one pressed (assuming you want last note priority, but there are more possible schemes once you keep state, possibly a per key state).
tz877398
PostPosted: Thu May 03, 2018 5:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think I understand what you are telling me, but I'm not quite sure how to use msg.isButtonUp for a specific key... any time i use if(msg.isButtonUp()) 0 => s.gain it sets the gain to 0, regardless of which button goes up. Are there other commands i'm not aware of?
I'm planning on meeting with my professor tomorrow, but i'm not certain he will know the answer either...he is a composer of electronic and computer music but from my understanding he is still learning how to use chuck as well. he encouraged the class to post on forums if we had any questions.
Audio files: 237
G2 patch files: 319
PostPosted: Fri May 04, 2018 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
How about ...
Code:
        if( msg.isButtonUp() ){
            if (msg.which == 29){ //Released Z
            // etc ...
... I would expect that to work.
