Constant-time linear portamento
Page 1 of 1 [4 Posts]
Chet
G2 patch files: 35
PostPosted: Mon Jul 04, 2005 8:12 pm    Post subject: Constant-time linear portamento Reply with quote  Mark this post and the followings unread
Attached is a patch that contains a constant-time linear portamento circuit. It has a straight slope like linear portamento, but has a constant time regardless of the interval, like logarithmic portamento. Basically, it's a linear portamento with a slope that is steeper for larger intervals.
There's some additional logic attached to a three-way switch which selects normal, auto, or off modes. A test oscillator creates a basic audio tone.
LinearPortamento.pch2
 Filename:  LinearPortamento.pch2
 Filesize:  1.6 KB
 Downloaded:  697 Time(s)
Audio files: 107
PostPosted: Wed Jul 06, 2005 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool, Chet.
Is this liniar portamento what one normally uses with strings. It seem more musical than a constant speed portamento. I mean, in music, you must finish your slides by the time the beat, or the portion of the beat, is finished.
I wonder why this isn't the default method for all synths.
Chet
G2 patch files: 35
PostPosted: Wed Jul 06, 2005 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I put it together to use with string sounds. I remember Ken Elhardt complaining about the Nord Modular portamento (a typical logarithmic portamento), and speaking of moving to Reaktor to get around the problem. But the problem can be patched around.
Linear portamento sounds more acoustic than log portamento to me, especially when it's an upward interval.
I think it perhaps a linear constant-time portamento should be the default mode on modern synthesizers. I can understand using log portamento back when engineers used resistors and capacitors, but it's all just algorithms now.
Audio files: 107
PostPosted: Wed Jul 06, 2005 8:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Chet wrote:
... it's all just algorithms now.
Ain't it the truth... Laughing
