Transposable arpegiator in real time ?
Page 1 of 1 [6 Posts]
nostromo974
PostPosted: Sat Sep 15, 2018 5:48 am    Post subject: Transposable arpegiator in real time ? Reply with quote  Mark this post and the followings unread
Hi
Is possible to transpose the G2 arpegiator in real time with another slot ?
exemple :
slot 1= synth patch+argegiator -
slot 2 = transpose arpegiator of slot 1 in real time with one note ?
thx
Electromagnetic Wave
G2 patch files: 38
PostPosted: Sat Sep 15, 2018 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes.
Edit : Welcome to the forum! Very Happy
Super merci, je vais essayer ça ce soir Wink
https://fr.audiofanzine.com/synthe-modelisation/clavia/Nord-Modular-G2/forums/t.675859,transposer-l-arpegiateur.html
So ?
nostromo974
PostPosted: Mon Sep 17, 2018 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Electromagnetic Wave wrote:
Yes.
So ?
Merci mais je comprends pas le patch que tu m'as envoyé Sad
Dans l'idéale j'aimerais un patch (ou une performance de 2 slots) avec un slot 1 vide dans lequel je pourrai mettre n'importe quel synthé/patch de mon choix et un slot 2 qui transposerait uniquement l'apergiateur activé dans slot 1 en temps reel avec un doigts.
Je ne sais pas si je suis clair et si c'est possible ?
merci Wink
G2 patch files: 38
PostPosted: Mon Sep 17, 2018 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I suggest that we continue in English so that all members of the forum can read it. But I'm much more comfortable in French too! We can go back on AF if you want.
Just say it and ask for help if you do not understand the patch! G2 Built-in arpeggiator does not send MIDI out. I suggest to use a 2nd slot with an DIY arpeggiator patch instead of using the built-in arpeggiator. Like the one I posted on AF. Several types of arpeggiators (monophonic, polyphonic, voice allocation, etc.) are available on the forum.
Tell me what you do not understand in the patch that I posted before
(the top part if you want to make a chord and change it to an arpeggio).
Edit : Here is a video I made for you.
https://youtu.be/Vh9E2ntjExw?t=7s
nostromo974
PostPosted: Sun Sep 23, 2018 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Génial ! merci je vais regarder la vidéo ça devrait m'aider Wink
Peux tu stp m'envoyer le patch de ta video ca je ne l'ai pas ? (mail : danielgarrigon@orange.fr)
DAN
G2 patch files: 38
PostPosted: Sun Sep 23, 2018 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
The top part is not mine. Yesterday I tried to find the initial patch without success. If someone recognizes the patch (top part) and can tell who the creator is, I'd be happy to add it to the patch (as a reference) and here in the discussion.
ArpDemo1.prf2
 Filename:  ArpDemo1.prf2
 Filesize:  6.04 KB
 Downloaded:  2804 Time(s)
