Charlie
Posted: Fri Jul 08, 2005 6:50 am Post subject:
about the combfilter |
hi everybody
I like a lot the combfilter of my waldorf Q and cannot recreate these big tube sounds with my G2. does someone have ideas on patching this filter ?
I know Rob have some superb patchs with custom lowpass filters but with the comb,... !!!
Thanks a lot
Charlie |
Tim Kleinert
G2 patch files: 236
Posted: Fri Jul 08, 2005 7:00 am Post subject:
Stupid question, but have you tried using the G2 comb filter module?
Anyway, conceptually, a comb filter is just a tuned delayline with feedback (a VC flanger with exponential tracking, if you want). In that sense, the sound shouldn't be THAT different from synth to synth.
Maybe the Waldorf Q comb filter has something extra going on in the feedback loop which makes it sound special. So, if you could post an mp3 of it in action, that would help us find out what you are looking for. |
Charlie
Posted: Fri Jul 08, 2005 8:30 am Post subject:
thank you,... for a first post,... it is very !!!
i know the principle of the comb filter and yes i already have patched this module. My question was about connecting it in conjunction with other modules, I'd like to have tips and ideas to use it to make it more musically interesting.
The waldorf Q and absynth have the edge that I like,... with the G2, it seems more difficult.
And saying a comb is a comb and is the same on every synth,... tsstsstsss,
thanks |
Tim Kleinert
G2 patch files: 236
Posted: Fri Jul 08, 2005 9:51 am Post subject:
never mind, I was just trying to help
"Musically interesting" and "edge" are highly subjective terms. Without audio examples, I can't know what you mean.
Anyway, my description of the comb filter actually does give some cues for its use:
1) since it is a tuned delay line, it lends itself nicely to physical modelling applications, as it has keyboard tracking already built into it.
2) since you can look at it as a flanger without a dedicated LFO, you can do all sorts of unusual flanging FX with it.
3) Turning keyboard tracking off and opening up the FB, you can use it as a static sympathetic resonator (for drone strings) too etc. I think I saw a sitar patch somewhere that did this.
I'm not at my home computer right now, so I cannot patch and post examples, but eg. there are bound to be physical modelling patches in the patch archive which use the comb filter.
hope this helps more. |
Audio files: 278
Posted: Sat Jul 09, 2005 4:25 pm Post subject:
Charlie wrote: |
Did you try looking at the waveforms coming from the implementations that you like? some aditional wave-shaping or overdive might be involved to fatten it up a little, especially in modern synths meant to have a edge. With digital filters you can afford to put the filter *after* the vca and use a bit of overdrive inbetween which often adds a little edge and expression.
Remember that the people here are volunteering to help you but can have no idea of your level of knowledge after just one post. _________________ Kassen |
Charlie
Posted: Sun Jul 10, 2005 7:47 am Post subject:
thank you all for your help
After a few days of experimenting, I have discovered new things and the result becomes really good !
Yes,putting the filter after the vca can do some good results, I will try with some overdrive !
It's the "problem" with the G2, considering it and patching it like a basic synth don't give good results and it is particulary difficult for a newbie !
On my first post, I just wanted to know if there was some exemples of "macros" using the combfilter like I 've seen with the low pass filters (reinjecting the output with "inv" +....)
Charlie |
