MiniMoog VCF behaviour question
hububalli
PostPosted: Fri May 03, 2019 8:15 am    Post subject: MiniMoog VCF behaviour question Reply with quote  Mark this post and the followings unread
All works as expected and have been through the calibration. The problem I am having is when I do the following;
Frequency range :
Apply a sinewave with frequency 32Hz to the audio input
Emphasis potentiometer to minimum resonance (fully counter-clockwise)
Turn the frequency knob fully counter-clockwise
Adjust T2, in order to mute the 32Hz signal
Then, even with the frequency cut off wide open, a lot of the treble end is being lost. If I turn T2 all the way back down, all the treble is back again. As soon as I turn T2 the treble end starts being cut out.
Is it just a case of finding a happy medium?
Thanks,
http://www.yusynth.net/Modular/EN/MOOGVCF/index.html
