Voice allocation question
Page 1 of 1 [7 Posts]
chapelier fou
PostPosted: Tue Jun 18, 2019 1:51 am    Post subject: Voice allocation question Reply with quote  Mark this post and the followings unread
Hi there,
on the G2, I can route each voice to a completely different synth chain with the help of the Mux modules.
I tried to do this on my micromodular but it does't seem possible. Am I missing something ?
chapelier fou
PostPosted: Sat Jul 06, 2019 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
This question matters to me, and I didn't find a workaround.
So forgive me for bumping the thread.
Audio files: 326
PostPosted: Sat Jul 06, 2019 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
The question did not seem clear to me (and was hoping it would be clear to others ... )... can you provide some more details?
Like .. what is an entirely different synth chain?
The NMclassic does have muxes IIRC (been a while since I used it) but the G2 cando far more complex routing.
chapelier fou
PostPosted: Sun Jul 07, 2019 12:58 am    Post subject: Reply with quote  Mark this post and the followings unread
For instance, how would you make a round robin voice allocation ?
voice 1 goes to one oscillator, voice 2 goes to another oscillator, etc....
Audio files: 326
PostPosted: Sun Jul 07, 2019 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah .. there are no proper multiplexers I now see ... but the pan module could be used I guess ... I did not test it, but maybe something like the attached patch?
maybe_something_like_this_01.pch
just a patch idea, untested
 Filename:  maybe_something_like_this_01.pch
 Filesize:  1.83 KB
 Downloaded:  380 Time(s)
chapelier fou
PostPosted: Mon Jul 08, 2019 12:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot.
I couldn't test but opened the patch nonetheless. I'm having a hard time trying to understand the logic !
Audio files: 326
PostPosted: Mon Jul 08, 2019 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
The idea is to have a binary counter with the divider modules, then use the pan modules as a demultiplexer controlled by the binary divider outputs ... the gate logic seems not correct in retrospect .. but would need some sample and hold trickery to get that right.
