Pehr
Joined: Aug 14, 2005 Posts: 1306 Location: Björkvik, Sweden
Wild Zebra
Posted: Wed Aug 24, 2005 6:39 am Post subject:
Boy your diving in head first huh. Sweet. This was my first BIG project, but its laid out so nice if you take your time and follow the instructions you can't go wrong. _________________ "your stripes are killer bro" |
Posted: Wed Aug 24, 2005 7:42 am Post subject:
Re: 0k, here's a pic of my first SL... |
| Pehr wrote: | I'm also having trouble finding 1/4W 5% resistors with the values 200k, 20k, 2M and 3M, but I'll figure something out...  |
perhaps you can find some at http://electrokit.se ? _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Pehr
Clack
Joined: Aug 08, 2005 Posts: 436 Location: Seven Sisiters - london
Posted: Wed Aug 24, 2005 8:18 am Post subject:
wow thats really nice/slick, you got those sexy knobs I cant find , where did you get them from? is it black laminated wood?
I had weird results with resistors , use accurate ones when joining them i got some really far off results. this program is great if you want parralell
http://www.computertorture.com/noncompliant/parallel/ gives you a table of possible combinations. |
Pehr
Macaba
Posted: Wed Aug 24, 2005 8:31 am Post subject:
| If you are really stuck, i've got those values in my spares collection, i'm sure we could come to an arrangement. |
Pehr
opg
Joined: Mar 29, 2004 Posts: 954 Location: Tucson, AZ, US
Posted: Wed Aug 24, 2005 9:14 am Post subject:
| Be sure to put up a sound sample when you are finished! I'm planning on building that SL from MusicFromOuterSpace in the coming months. |
Pehr
dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
Posted: Wed Aug 24, 2005 9:34 am Post subject:
wau -Pehr you are fast!
it looks really good
i have been doing my SL for about 6 moths ?
and i´m stuck whit the panel and many mods . . .
but soon i will join the SL club...
good luck whit wiring up
dnny _________________ Association of experimental electronics
www.koelse.org
flickr: cable porn group |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Wed Aug 24, 2005 9:37 am Post subject:
Pehr, looks great. Congrats. _________________ --Howard
my music and other stuff |
Wild Zebra
Posted: Wed Aug 24, 2005 9:40 am Post subject:
Sorry to jump in, but it sorta is on track. A while ago I made the sample and hold and I didn't have a 330k resistor so I put two in parallel.
Well without thinking I assumed a 300K in parallel with a 30K would make 330k is this correct? Does series or parallel make a diff with resistors?
I would think not? I know it seems like a silly question.
It shows my electronic ignorance and newbism _________________ "your stripes are killer bro" |
Audio files: 107
Posted: Wed Aug 24, 2005 9:49 am Post subject:
Resistors in serial are added. 300K in series with 30K is 330K. Parallel is more complicated.
If there are just to the resistors in parallel the equation is
Reffective = (R1 * R2)/(R1 + R2)
It's called the product over sum rule. _________________ --Howard
Wild Zebra
Posted: Wed Aug 24, 2005 9:52 am Post subject:
So I reckon I should get out the old solder braid and put'em in series. Maybe thats why its acting up.
How bout caps 2x 1uf in parallel = 2uf? Or is it the same type of theory _________________ "your stripes are killer bro" Last edited by Wild Zebra on Wed Aug 24, 2005 9:54 am; edited 1 time in total |
Pehr
Audio files: 107
Posted: Wed Aug 24, 2005 10:01 am Post subject:
You are right. Caps in parallel - add the two values together. It's the opposite of resistors. _________________ --Howard
Wild Zebra
Posted: Wed Aug 24, 2005 10:10 am Post subject:
Learning all the time. Well the rate pot on my S&H seems to bunch up real bad about half way through and the said resistor is in line with the pot
so I bet when I put em in series, boo yah. Its gonna work. Hopefully I haven't damaged anything. It seems to work fine excepy for the rate.
Hey thanks for your help MOSC and Pehr(and sorry for the thread hijack) _________________ "your stripes are killer bro" |
Etaoin
Joined: Jun 30, 2005 Posts: 760 Location: Utrecht, NL
Posted: Thu Aug 25, 2005 5:20 am Post subject:
| Quote: | I'm also having trouble finding 1/4W 5% resistors with the values 200k, 20k, 2M and 3M, but I'll figure something out...  |
I found that while impossible to find over here at 5%, they were pretty much stock items everywhere at 1%, which I guess is even better anyway. Since I needed to buy those 100 at a time, if anyone in or near the Netherlands needs some 200k, 20k or 2M, I have plenty left... The only one I couldn't find in the end was the 3M one. |
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Fri Aug 26, 2005 1:39 pm Post subject:
The 2M I made from 1M*2 in series.
The 3M I made from a 1M8 and a 1M2 in series which are heaps easier to find.
Just be sure to check the total before you put it in.
Anything you can't find in 5% is better in 1% _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
Audio files: 107
Posted: Fri Aug 26, 2005 4:13 pm Post subject:
Here's another trick that might be helpful. 1%, 5% and 10% resistors are virtually all the same, they are just speced to be closer to the exact value. So, if you have a bunch of 10% 10K resistors for example, and the spec is for 5% ones, just measure the ones you have. If the value is withing 5% of 10K (9500 and 10500) then consider it as a 5%. The same trick can be used to find resistors that are within 1% of the specified value. Sometimes you'll be lucky and find some good ones. The resistors themselves won't age any differently. _________________ --Howard
Pehr
Wild Zebra
Posted: Wed Sep 07, 2005 7:43 am Post subject:
Alright, alright sweet all done. Nice sound file. I'm about to post some completed photos I finally got from a friend.
Ever hear of the Tall Dwarves? I think they are/were from New Zealand
anyway 2 guys they moved apart after awhile and started sending Tracks back and forth to make their records. Thay did an Album were they asked fans to send tape loops or single tracks and they recorded an album around them. Pretty sweet record. Well maybe a International
Sound Lab recording is in order. Huh Huh maybe. Record a track and pass it on. Just a thought. _________________ "your stripes are killer bro" Last edited by Wild Zebra on Wed Sep 07, 2005 12:47 pm; edited 1 time in total |
Macaba
Posted: Wed Sep 07, 2005 8:01 am Post subject:
Ow. That sound file reaches painfully high frequencies. Ow.  |
Pehr
