Hello New Member
Page 1 of 1 [3 Posts]
cosmosuave
PostPosted: Fri Sep 23, 2005 12:03 pm    Post subject: Hello New Member Reply with quote  Mark this post and the followings unread
As a new member I would like to say hello and mention that I almost
have my Soundlab completed... I came across the SoundLab from a post at livepa.org
and figured it was fairly straight forward project to build... I started in May and have
just about completed it... I have mounted it in a wooden desktop case and all I have
left to do is wire the PCB to the control panel... Once completed I plan on using the sounds of Soundlab to compliment my Live Pa performance... Good thing I have held on to my Roland MC4 this will be great for sequencing the SL... I may even instal the SYnhouse midijack...
I have a question regarding a 2.2uf ceramic cap (C13) that is wired to power switch (S17).
I am unable to source that cap and was wondering if I can use a 2.2uf tanatalum cap?
If so where would the + lead of the cap connect to? S17 or R88? The dude at the electronics
supply gave me a 2.2uF cap but it is huge in physical size and I believe this is not the right one...
Thanks...
Wild Zebra
PostPosted: Fri Sep 23, 2005 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well hello!!
I had mine SL for a little while now. Haven't recorded or used for any live stuff, but I can tell you its truly a sweet project and play around with it just about everyday. Heres the link to th SL page dicussing you cap dilemma. Or use 2 1uf's in parellel I think thats what I did.
http://www.musicfromouterspace.com/analogsynth/SOUNDLABMINISYNTH/soundlab.html#CAPNOTE
Hope that helps. Keep us posted and welcome.
"your stripes are killer bro"
cosmosuave
PostPosted: Fri Sep 23, 2005 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks I just noticed revisions to SL web site... Will go and source those 4.7 uF caps tonight
Niio1
