Multimode filter with single-knob mode control
Page 1 of 1 [5 Posts]
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sat Nov 05, 2005 12:16 am    Post subject: Multimode filter with single-knob mode control Reply with quote  Mark this post and the followings unread
This building block provides a filter with variable LP-BP-HP-Notch response, and one knob is used to gradually crossfade through all modes.
It uses a multimode filter with the LP, BP, and HP outputs connected to the inputs of a x-fade mux module (plus a separate 2-1 mixer that combines the LP+HP to provide the notch response, connected to another input of the mux). The mux crossfade effect is controlled by either a knob (D1:3) or an LFO sweep (D1:4).
The LP response is connected to both the first and last positions of the mux so that a sawtooth wave from the LFO will cause the modes to cycle through LP-BP-HP-N-LP-BP-HP-N ... etc.
Try the variations. Enjoy!
MuxModFilter template.pch2
Multimode filter with single-knob mode crossfade control
 Filename:  MuxModFilter template.pch2
 Filesize:  1.59 KB
 Downloaded:  656 Time(s)
Dave Peck
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Sat Nov 05, 2005 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, this is a great idea!
However, I'm puzzled. Is the separate notch stage really necessary? I mean: if you have the LP and HP next to each other in the xmux configuration, you'll get the notch stage anyway...
beer
Audio files: 116
G2 patch files: 317
PostPosted: Sat Nov 05, 2005 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice patch !
Could use it in some noodle.
cebec
G2 patch files: 31
PostPosted: Sat Nov 05, 2005 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice, Dave! a lot of fun...
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sat Nov 05, 2005 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah yes, you are correct! I just did it this way because I preferred the way the knob responds. This way, full left & full right are LP, straight up is HP, and BP and Notch are both equally spaced between these.
There are lots of variations on this idea that could yield some cool results - like for example using two different sounding filters that track identically, so your LP position could be 24dB/oct with some overdrive while your HP position might be 12dB/oct and clean....
Dave Peck
Niio1
