waveshaping ideas
Page 1 of 1 [2 Posts]
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sat Nov 12, 2005 10:14 pm    Post subject: waveshaping ideas Reply with quote  Mark this post and the followings unread
Here's a partly finished patch that uses some waveshaping techniques described in the "Waldorf Osc" thread. Playing low notes makes the shaping effects more audible.
Two shaper oscs are independently swept, both are connected to a crossfader which is modulated by an audio osc. The resulting waveform is made of ShapeOsc1 for the positive half, and ShapeOsc2 for the negative half.
These are then sent through two different shapers which are also crossfaded by an audio osc to further mess with the positive & negative halves of the wave in different ways.
Then a set of frequency-tracking resonant HP filters set to low fc's to emphasize the fundamental & 3rd harmonic (with manual crossfader to set the mix of this effect). Check out the first four variations. Enjoy!
ShaperFaderPad.pch2
Various waveshaping ideas, using an audio osc to crossfade between two signals for asymetrical shaping.
 Filename:  ShaperFaderPad.pch2
 Filesize:  2.57 KB
 Downloaded:  1036 Time(s)
Dave Peck
Bensen Raccoon
G2 patch files: 8
PostPosted: Tue Nov 22, 2005 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
that's beautiful dave. nice work!
It is the jigsaw, it is purple haze, it never stays in one place, it is not a passing phase.
