g2 pitch stick and controllers question
Page 1 of 1 [3 Posts]
sidx
PostPosted: Sat Nov 26, 2005 5:06 pm    Post subject: g2 pitch stick and controllers question Reply with quote  Mark this post and the followings unread
dunno what is this - the range between right board of stick and right edge of stick-hole is bigger then a range of left side.
its like in a picture http://www.avallonltd.com/pics/clavia/nordmodularg2.jpg
but here maybe is an isometric projection in photo.Buti have this space REAL.Is it normal?
and anotther thing i was scared - if i try to shake a bit my g2 controllers - i can hear a sound somtheing like crackle...like a minor sand under controller - is this normal too? maybe i break something? =( But my g2 kept very carefull.And controllers not usings very often.Plz help if u know something about this.THanx
p.s. sorry for bad english
Audio files: 139
PostPosted: Sat Nov 26, 2005 7:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I took a careful look and listen to my G2X and I think everything you are seeing is normal.
The pitch stick is not perfectly centered, but very close to it.
The very soft sandlike sound is from the micro detents in the encoder controls. Nothing, in my opinion, to worry about.
sidx
PostPosted: Sun Nov 27, 2005 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
about pitch-stick -
if i push it to left and touch the edge of hole - tone change function finishing perfect in this time too.If do this to right side - tone change function will finish but there will also a little space before edge of hole.
Understood about sandle noise - thanx a lot for make me quiet.
