Syncing Laptops
Page 1 of 1 [4 Posts]
Scott013
PostPosted: Wed Jan 04, 2006 6:56 pm    Post subject: Syncing Laptops Reply with quote  Mark this post and the followings unread
I've been talking with a few guys and we discussed getting an electronic group together, we would mainly use laptops and software bcause it is much cheaper for us than hardware at the time.
So I'm curious how we could all sync together? To make sure we are all always at the same place in a song as everyone else.
paul e.
PostPosted: Wed Jan 04, 2006 8:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
pick one laptop to be the 'master' clock...set your DAW to spit out MTC thru a midi interface...hook everyone in...make sure all 'slave' laptops are set to receive MTC...
if you don;t have a multiple in/out midi interface, you will have to use the 'thru' port to pass the MTC along the chain
possible troubleshooting: make sure the MTC frame rate is the same on all machines [30fps, 25fps etc]
in a pinch, Midi Clock will work..sort of
Spiral Recordings
diskonext
PostPosted: Thu Jan 05, 2006 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I heard a lot of people have troubles with PCs (ie non-dedicated hardware) as a master MIDI device, and I have had some bad experiences with that myself.
There are some standalone MIDI clock generators, can't think of any names right now, that might be had cheaply )eBay etc) and would keep things a lot tighter.
-diskonext
:wq
Scott013
PostPosted: Thu Jan 05, 2006 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Doesn't sound too hard, thanks for the help guys.
JuneSolstice2013
