Chet
Joined: Nov 19, 2004 Posts: 231 Location: Lititz,PA,USA
G2 patch files: 35
Posted: Wed Jan 25, 2006 10:35 am Post subject:
V1.4 editor crashes when saving prf after cut/paste |
Using the attached performance, I can get the editor to crash when I follow these steps:
1. Go to slot D.
2. Highlight all modules by choosing 'Select All' from the 'Edit' menu.
3. Put the modules in the cut/paste buffer by pressing ctrl-C.
4. Click on the FX area in slot D.
5. Paste the modules into the FX area by pressing ctrl-V.
6. Attempt to save the performance to disk. The editor will crash.
My environment is:
Windows XP SP2
V1.4 editor.
The G2 is not attached.
I reported a similar problem in v1.32. It looks like a fix didn't get into this update. Last edited by Chet on Tue Oct 13, 2009 9:50 am; edited 1 time in total |
Audio files: 278
Posted: Wed Jan 25, 2006 1:09 pm Post subject:
I can't reproduce this, not with the G2 detached and not with the G2 attached. Also XP SP2 & 1.4. _________________ Jan
Chet
G2 patch files: 35
Posted: Wed Jan 25, 2006 1:46 pm Post subject:
Hmmm...I'm glad it works for you. But for me, it still crashes the editor when saving to disk.
Just checking, when you save it, I suppose the file size is significantly bigger than the 55k performance I posted? |
Audio files: 278
Posted: Wed Jan 25, 2006 2:10 pm Post subject:
It's still in the ... erm .. recycle bin ... and it's 55 K _________________ Jan
Chet
G2 patch files: 35
Posted: Wed Jan 25, 2006 2:20 pm Post subject:
Now I'm confused. If you copied and pasted all the modules from the slot D VA area to the slot D FX area, and saved it to disk, I think it should've grown bigger than the original 55k file. There were a lot of modules in the slot D VA area. |
Audio files: 278
Posted: Wed Jan 25, 2006 2:23 pm Post subject:
Erm I cut 'm, not copied, I'll retry.
Edit : Ok, can reproduce it now, sorry for the fuzz - the file is unmodified seemingly by the crash. |
Chet
G2 patch files: 35
Posted: Wed Jan 25, 2006 2:49 pm Post subject:
Thanks for re-trying. I'm glad (I suppose) that it can be reproduced.
I think there's some kind of size limit to performances. Attached is a performance that contains nothing but SeqCtr modules (unwired). There are 80 SeqCtrs in slot A, with 40 in the VA area and 40 more in the FX area. Slot B is identical, with 80 more SeqCtrs. If I try to copy/paste one of the batches of 40 SeqCtr modules to slot C, the editor will crash when I try to save it. I suppose it's another occurrence of the same problem. Last edited by Chet on Tue Oct 13, 2009 9:52 am; edited 1 time in total |
Audio files: 278
Posted: Wed Jan 25, 2006 3:07 pm Post subject:
Yes, that crashes the editor here as well.
55 K is a huge patch BTW, from a random set of about 600 patches I scanned I've got 13 that are larger than 20 K, none that are larger than 30 K. I had seen one of your patches a while ago to be something like 50 K, I guess you really are the only one likely to run into this problem :-) or :-( rather :-) _________________ Jan
Posted: Wed Jan 25, 2006 5:29 pm Post subject:
I can't attempt to reproduce your problem at the moment, but I noticed in the readme over the last few versions that some fixes were made for large *patches*, since some very large patches also caused crashes (but have now been fixed).
Maybe Clavia just needs to be reminded/reiterated, that this is a *performance*. And now that 2 people can reproduce the exact problem, that should help them fix it as well. |
Audio files: 278
Posted: Wed Jan 25, 2006 5:40 pm Post subject:
jksuperstar wrote: | *performance* |
Just to be sure, where I said patch in the previous I meant "patch and/or performance". I'm a bit sloppy on that. |
Chet
G2 patch files: 35
Posted: Wed Jan 25, 2006 5:59 pm Post subject:
OK, I think I've found what's going on: Clavia is using 16-bit math somewhere, and when a patch gets larger than 65,536 bytes, an overflow exception occurs and the editor shuts down.
I've experimented with incrementally increasing the size of a performance by adding SeqCtr modules one a time until the editor crashes. The last successful save was when the performance size was 65,517 bytes. My extrapolation tells me that one more SeqCtr module was enough to blow out the 16-bit math limit.
Who uses 16-bit math anymore? Maybe it's a limitation of the controller CPU inside the G2 itself.
Bummer. But at least now I know why.
Jan, thanks for your help in verifying this. |
Posted: Wed Jan 25, 2006 6:01 pm Post subject:
Listen Jan, in this case I guess it would be about 16-bit math and not shoeboxes. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Audio files: 278
Posted: Wed Jan 25, 2006 6:15 pm Post subject:
Chet wrote: | OK, I think I've found what's going on: |
a 16 bit limit ... I wouldn't have thought on that ...even when today I've been using some 24 bit math even. For a controller, yes.
Let's hope it is a non necessary limit, but I fear ... _________________ Jan
ian-s
Joined: Apr 01, 2004 Posts: 2669 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 626
Posted: Wed Jan 25, 2006 6:34 pm Post subject:
Chet wrote: | Who uses 16-bit math anymore? Maybe it's a limitation of the controller CPU inside the G2 itself.
Its common (but bad) practice with C to pre-allocate a buffer that is much larger than you think you will need, then assume you never need to check.
Of cause you fully intend to go back latter and do it properly
Some people love C, some hate it, I think its just average. |
