Building The Appendage. Share your Experiences
Page 1 of 6 [147 Posts]
Sound
PostPosted: Wed Mar 31, 2010 3:15 am    Post subject:  Building The Appendage. Share your Experiences
Subject description: A place to ask questions or just show off
Hello I open this thread for share the building process of our appendages.
So ill start with a question... Laughing
I would like to add a switch in the front panel for length ribbon selection. I mean instead the internal jumper JMP1.
In order to use different ribbons.
Looking at the schematics -page D-2- I wonder if VR12 trimmer resistor should be adjusted depending on the ribbon length. I mean if a ribbon of for example 50cm will need same VR12 adjustment than other ribbon, say 100cm.
Anyone?
PostPosted: Wed Mar 31, 2010 3:36 am    Post subject: Reply with quote  Mark this post and the followings unread
The whole setup and calibration would need to be re-done for a different ribbon. AFAIK.
Funky40
G2 patch files: 5
PostPosted: Wed Mar 31, 2010 3:58 am    Post subject: Reply with quote  Mark this post and the followings unread
how much trimmers to set up ?
if not too much one could bring them to the frontpanel.
i also like to connect the appendige to ribbons from differenth lenght
( have not studied any docs yet )
PostPosted: Wed Mar 31, 2010 5:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Funky
Andy is correct. There would be several trimmers that would need to be adjusted to account for the different ribbon lengths and thus resistance. It would not be a matter of just bringing out the trimmers to a front panel but also several "test points" to measure voltages. Although the Appendage has a vast amount of strong attributes, this is one of it's weaknesses, the lack of having a ribbon "length" selection that would NOT require any recalibration. So, it's the 500 mm ribbon, or a smaller one, exclusively.
Hmmm, maybe version 2.0 will have an autocalibrate function. Wink
Bill
PostPosted: Wed Mar 31, 2010 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Funky, I would like to make this topic Sticky and rename it:
SUBJECT: "APPENDAGE BUILDS, Share your Experiences" ....
SUBJECT DESCRIPTION: "A place to ask questions or just show off"
OK to do that?
Bill
Sound
PostPosted: Wed Mar 31, 2010 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
OK to do that?
Bill
Done.
Sound
Thanks Uncle.
PostPosted: Wed Mar 31, 2010 3:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Done.
Awesome !
Bill
Danno Gee Ray
PostPosted: Wed Mar 31, 2010 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nothing beats having a Sticky Appendage......thread.
mark_olson
PostPosted: Wed Mar 31, 2010 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Agreed. But I think it isn't actually yet. We need to flag down one of the mods.
Mark
PostPosted: Wed Mar 31, 2010 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, I just made it stick ..... lol ... now we can truly say the Appendage is sticky !!
Laughing
Bill
Sound
PostPosted: Thu Apr 01, 2010 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello , working around the idea attached, 1U rack.
How do you see it? Any opinion will be welcome.
About the INPUT MODE switch, I would like to know if it affects to both, the ribbon input and sample input, or only to the sample input?
 Filesize:  86.17 KB
 Viewed:  1554 Time(s)
PostPosted: Thu Apr 01, 2010 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
The "INPUT MODE" only applies to an INPUT "SAMPLE". The "UNIVERSAL" processes external inputs that change smoothly. The "STEPPED" input processing is good for, well, stepped inputs like those from external CV keyboards like my IKC or ones from Doepfer, MOOG, etc ...
This is reason why I designed the graphics on my panel to indicate the "INPUT MODE" function is exclusive to the "SAMPLE" inputs by drawing a line between them.
Hope this helps Sound Very Happy
The panel looks nice and compact, nice job so far man !
Bill
 Filesize:  38.61 KB
 Viewed:  73872 Time(s)
Sound
PostPosted: Thu Apr 01, 2010 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Bill this helps a lot, Ill modify a little the design accordingly.
oldmanfury
PostPosted: Sun Apr 04, 2010 5:36 pm    Post subject: my panel design Reply with quote  Mark this post and the followings unread
Here's what I ended up doing. Pretty happy with the results, nothing was too cramped. I did end up grouping knobs / switches / I/O separately, which has its pros and cons.
-gerald
I used FPD for layout - and hand drilled the panel myself, so the text and etchings are not in perfect locations.
 Filesize:  58.02 KB
 Viewed:  1395 Time(s)
Appendage.fpd
Front Panel Express panel
 Filename:  Appendage.fpd
 Filesize:  1.88 KB
 Downloaded:  1302 Time(s)
Photon
PostPosted: Sun May 30, 2010 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Perhaps this is common knowledge, but I noticed this morning that Jameco sells Softpots. The 500mm (item 2082708) is $21.95 and the 200mm (item 2082679) is $14.95.
slo
PostPosted: Mon Jun 21, 2010 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Appendage preliminary design, 17" panel to go in custom controller
Think I've got everything there, as you can see I did attempt to split it into the 3 sections. Made in Front Designer 3.0.
George
Appendage front panel
 Filesize:  36.14 KB
 Viewed:  1462 Time(s)
PostPosted: Mon Jun 21, 2010 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
George
Nice so far George Very Happy The layout is very logical. I would like to make a suggestion. Since you had added multis to the TRIG and GATE signals, you might want to add some for all the CV outputs. You will definitely find that you will want to control more then one thing off a single output.
Nice work !
Bill
slo
PostPosted: Mon Jun 21, 2010 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the input Bill, I'm a bit contricted in the design as I want to have all jacks at the top so as not to interfere with the ribbon below the panel, (cords sticking out) but I will think about it...........multis are good!
George
PostPosted: Mon Jun 21, 2010 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure George, your welcome. Another approach is to just make a few "Y" cables and use those as your multis thus no panel space required.
Have fun with it ... it's looking great. I am loving the keyboard/ribbon controller rig your building.
Bill
PostPosted: Mon Jun 21, 2010 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dam Pete, your right. Just now looked at the Jameco catalog and there they are Wink Thanks for giving everyone a heads up Very Happy
Bill
slo
PostPosted: Tue Jun 22, 2010 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any of you fine folks know where I can get a 3.5mm isolated TRS jack from, I've searched Mouser hi and low and come up with nothing. I would like to stay with that size for the Appendage ribbon connection.
George
Danno Gee Ray
PostPosted: Wed Jun 23, 2010 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try Mouser PN. 161-3402-E
Kobicon 3.5mm Stereo
PostPosted: Wed Jun 23, 2010 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
161-3402-E
Hmm, be careful Dan. There is no indication on the data sheet that it is isolated. The ribbon TRS jack must be isolated. Just double check me on this guys Wink
I did find this which may fit the bill quite nicely:
https://www.3dhdsupply.com/ProductDetails.Asp?ProductCode=30-711
Bill
Danno Gee Ray
PostPosted: Wed Jun 23, 2010 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Roger that. The Kobicons do have a ground lug that is connected to the panel / frame. My bad.
