Alternatives to BCR2000
Page 1 of 1 [13 Posts]
monobass
G2 patch files: 12
PostPosted: Thu Nov 29, 2007 5:42 pm    Post subject: Alternatives to BCR2000 Reply with quote  Mark this post and the followings unread
I need a USB interface with at least 16 'endless' Rotary Encoders.
Any alternatives to the BCR2000?
Steve
Mohoyoho
PostPosted: Thu Nov 29, 2007 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
CME Bitstream 3X
Doepfer Drehbank or Pocket Control
Faderfox
Akai MPK49
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
monobass
G2 patch files: 12
PostPosted: Fri Nov 30, 2007 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, thanks.... but none of those are USB interfaces with at least 16 'endless' Rotary Encoders Smile
Steve
monobass
G2 patch files: 12
PostPosted: Sun Dec 02, 2007 5:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Can anyone tell me what the distance is between two knobs on a BCR2000? i.e. center to center on two knobs.
I'm considering taking one apart and integrating into a DIY interface. If anyone has ever taken one apart or has internal photos that would be great Smile Interested to know how easy it is to pop the individual Encoders out of the chassis...
Steve
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Dec 02, 2007 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
it's 2.7/2.8 centimeters
monobass
G2 patch files: 12
PostPosted: Sun Dec 02, 2007 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Smile
Steve
Frank Luchs
PostPosted: Wed Jan 02, 2008 5:57 pm    Post subject: taking one apart Reply with quote  Mark this post and the followings unread
_ Steve _ wrote:
I'm considering taking one apart and integrating into a DIY interface. ...
Steve, that's interesting!
If you start your operation on this guy, would you mind taking some photos ?
step-sequencer
music
buzzr
PostPosted: Thu Jan 03, 2008 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Use the Kenton Killamix Mini. Should easily solve your problems.
monobass
G2 patch files: 12
PostPosted: Thu Jan 03, 2008 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very cool Kenton product... expensive though!
I bought a 2nd hand BCR2000 and have taken it apart and have taken photos of every stage so Will definitely post them online somewhere when I get a chance.
Steve
Frank Luchs
PostPosted: Thu Jan 03, 2008 12:56 pm    Post subject: BCR2000 LED ring Reply with quote  Mark this post and the followings unread
Cool! Cool
What can you say about the LED ring, is this an individual component or just LEDs on the board?
step-sequencer
music
monobass
G2 patch files: 12
PostPosted: Thu Jan 03, 2008 3:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Everything is individually soldered straight onto the board.... i.e. every LED is seperate... Shocked so it's no simple job to change the form factor of the knobs! But I may attempt it.. I don't know yet... I need to read up on the finer points and hazards of Desoldering first! I don't think any of the elements are paricularly fragile though, LED's, switches and pots basically. there aren't really any IC's mounted that close by on the board. Will sort out the photos over the weekend.
Steve
buzzr
PostPosted: Thu Jan 03, 2008 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the amount of effort you will put into this thing, seems like you could go the way of Midibox.org instead.
I'm going to be making a controller myself soon that will be like the doepfer pocket dial with extra buttons and note on and offs...and not using any kind of premade pcb's etc. i eventually will have it for sale but not for a while..
hopefully namm this month will have some new midi controller thingie.
monobass
G2 patch files: 12
PostPosted: Fri Jan 04, 2008 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes I think you're right about Midibox.org
Steve
