 Forum index » Clavia Nord Modular » G2 Patches - Completed » FX
Granular Synthesis
Page 1 of 1 [13 Posts]
Rob
G2 patch files: 109
PostPosted: Thu Jul 15, 2004 5:06 pm    Post subject: Granular Synthesis Reply with quote  Mark this post and the followings unread
Here is a FX patch that grinds audio down using the granular synthesis technique.
Especially Var4 is imho nice with piano only pieces, like Satie or something.
Each voice produces four grains. The patching is actually straightforward, it shouldn't be too difficult to analyze if you're into this kind of thing.
And if you're not into this kind of thing I can understand, I don't see myself why some people seem so crazy about granular synthesis. Still, its fun to play with now and then.
Btw, in V1.20 there is a little bug in the delay line modules that under certain circumstances causes glitches in the sound. Clavia says the bug is known and fixed and an OS bugfix update will be made available very soon on their site. This update will be only the OS Updater, the Editor is fine.
GranularEFX.pch2
Granular Synthesis EFX patch, uses the audio inputs to grind external audio.
 Filename:  GranularEFX.pch2
 Filesize:  6.94 KB
 Downloaded:  2668 Time(s)
jamos
G2 patch files: 41
PostPosted: Thu Jul 15, 2004 5:43 pm    Post subject: Re: Granular Synthesis Reply with quote  Mark this post and the followings unread
Is that the source of the background noise in this patch? I'm running it with no input right now and it sounds like a chorus of insects...
I've also had some clicking from the delays when run in Tempo mode with no input. Will the update solve that?
(BTW - I suspect this will be a great patch - haven't run anything into it yet though - )
Rob
G2 patch files: 109
PostPosted: Fri Jul 16, 2004 2:28 pm    Post subject: Re: Granular Synthesis Reply with quote  Mark this post and the followings unread
Yep, that's right. Seems to have been caused by some rounding error or something. Seems Clavia is collectively on holiday right now, so I think they will publish the fix when they're back in two weeks(?) time or so.
Rob
G2 patch files: 109
PostPosted: Sun Jul 18, 2004 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
The update is posted at http://www.clavia.se/G2/software.htm#synthupdate
paul e.
PostPosted: Tue Jul 20, 2004 2:20 pm    Post subject: Re: Granular Synthesis Reply with quote  Mark this post and the followings unread
jamos
is your avatar a screenshot of SuperCollider ?
Spiral Recordings
jamos
G2 patch files: 41
PostPosted: Tue Jul 20, 2004 2:23 pm    Post subject: Re: Granular Synthesis Reply with quote  Mark this post and the followings unread
Nope, just some of my Techno Toys code. I was going to mask it with an outline of my head from another pic (codehead - get it? Rolling Eyes), but got lazy.
OK, I edited the image. Thanks for the prod!
paul e.
PostPosted: Tue Jul 20, 2004 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
thumright
Spiral Recordings
Audio files: 224
PostPosted: Wed Jul 21, 2004 10:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Techno Toys still rules! Your Seq-303 is much more powerful and musical than the sequencers in the NM.
Audio files: 297
PostPosted: Fri Dec 03, 2004 6:41 am    Post subject: Reply with quote  Mark this post and the followings unread
In http://electro-music.com/forum/post-26354.html an mp3 made with the granulator patch can be found.
Jan.
Sander_k
G2 patch files: 16
PostPosted: Mon Feb 14, 2005 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I totally disagree.. seq-303 doesn't even come close Question
Audio files: 224
PostPosted: Mon Feb 14, 2005 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Everyone is entitled to their opinion. Very Happy
Sander_k
G2 patch files: 16
PostPosted: Tue Feb 15, 2005 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's true Laughing i just couldn't resist letting it shine through too much
Some features of it would be really handy. The back&forth option and the random 'nervous' skipping through the sequence. And the easy 1/4 1/8 1/16 switch, not to forget the on/off for every step... ok ok it was good!!! Very Happy
Audio files: 224
PostPosted: Tue Feb 15, 2005 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes and control of multiple controls, like volume, panning and whatever. Don't forget the banks of settings so you can varry the patterns in real time, either on the measure boundaries or asynchronously. Very Happy
I'm not biased just because the fellow who wrote it is a member here. Laughing
