Coriolis
Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
Posted: Mon Feb 25, 2008 5:16 am Post subject:
PCB layout for Ian Fritz' AD/AR EG Subject description: ..built one and it works |
Hi all
I recently did a pcb-layout of the simple little AD/AR circuit presented to the forum by Ian Fritz...here:
http://electro-music.com/forum/topic-21723.html&postorder=asc&highlight=envelope+generator+ian
He mentions an addon to it here:
http://electro-music.com/forum/topic-21723.html&postorder=asc&highlight=envelope+generator+ian&start=25
I built mine without the trun switch, but the pads are included on the layout.
The jumper betwen the opamp and the 4.7uf cap is where you mount one side of both pots - the other side goes to either the A or D, depending on whether you are wiring Attack or Decay. Solder the wiper to the A/D leg of the pot, and you've got longer A/D times turning the pot clockwise.
I used 1N4148 for the diodes, and added supply caps and 22R resistors on the supply as well (the Ken Stone trick).
Didn't provide pads for the x and y inputs found on the schem, but if you want to add the delayed pulser like Ian has it on his units, I guess you could just hang that off the leg of the 390K resistor going to +input of A1.
Haven't tried that myself though.
Hope this is useful to someone - it's my first layout contributed to this forum, so I'm kinda proud of it...
Best,
C
Edit: I should say: This layout is ready for Press and Peel.
| Description: |
| Filesize: |
50.95 KB |
| Viewed: |
1221 Time(s) |
| Description: |
| Filesize: |
33.47 KB |
| Viewed: |
1026 Time(s) |
RF
Joined: Mar 23, 2007 Posts: 1502 Location: Northern Minnesota, USA
Audio files: 28
Posted: Mon Feb 25, 2008 6:17 am Post subject:
Nice job - thanks for sharing this, Coriolis!
This is a nice circuit - I've got a pair of these in my newest cab and I them a lot.
bruce |
Coriolis
Posted: Tue Feb 26, 2008 2:20 am Post subject:
Thanks Bruce.
Yeah, I figured this was such an easy build, easy to use and low in panel real estate, that i had to try it.
For some reason I find ADSR's a bit confusing to use, or perhaps to much hassle to set up. I like to adjust envelopes a lot, and I feel the AD/AR types work better for me.
Perhaps I will do a layout for the delayed pulser as well, if it's ok with Ian?
C |
frijitz
Audio files: 54
Posted: Tue Feb 26, 2008 10:05 am Post subject:
| Coriolis wrote: | | Perhaps I will do a layout for the delayed pulser as well, if it's ok with Ian? |
Sure! You could even put it on the same board. Just a couple of suggestions: (1) Be sure to use the CMOS version of the 555 (or 556). (2) Watch the PS routing and bypassing. Even with the CMOS version I like a decoupling cap at the chip and separate PS runs back to the board's power in.
Ian |
loss1234
Coriolis
Posted: Tue Feb 26, 2008 2:33 pm Post subject:
| Quote: | | (1) Be sure to use the CMOS version of the 555 (or 556). (2) Watch the PS routing and bypassing. Even with the CMOS version I like a decoupling cap at the chip and separate PS runs back to the board's power in. |
Noted.
Other new layouts?
Weeelll..I do have a layout of an MFOS stereo panning mixer, and a layout of my take of the Baby 10 sequencer (Baby 8 in my case). The latter also features my ridiculously overkill debouncing solution for reset and manual step - nothing less than a oneshot with a 555 would work consistently for me!
There is also an onboard (555 based) clock.
What it should have but doesn't, is voltage buffers on the gate output (summed gate out and individual) otherwise driving multiple cv inputs gets weird fast. Maybe it would also benefit from an actual trigger out, to drive eg's better when clocked fast...
Buffers are too easy to do on perf or vero for me to bother adding them to the pcb though...
No wiring diagram for this - but take a look at fonik's Baby10 schematic, that's what I used for wiring (thanks for that, fonik!)
I'll post these layouts tomorrow, just have to go over them a last time.
C |
Wild Zebra
Posted: Wed Feb 27, 2008 1:13 pm Post subject:
Stereo panning mixer ehh. Is that the one with the general purpose mixer board?? As I was just getting ready to etch a few. Did you alter it in some was. I know it's got alot of area that doesn't get used. _________________ "your stripes are killer bro" |
Coriolis
Posted: Thu Feb 28, 2008 5:00 am Post subject:
Hmm, to be honest I took that multipurpose layout, shaved some things off, added some of my own. I really need to correct a few things though - don't have time till after the weekend I'm afraid...
C |
Wild Zebra
Posted: Thu Feb 28, 2008 9:17 am Post subject:
Cool I probably won't get around to it it till next week or so. I'll keep an eye out. _________________ "your stripes are killer bro" |
bugbrand
Joined: Nov 27, 2005 Posts: 846 Location: Bristol, UK
Posted: Sun Mar 02, 2008 11:03 am Post subject:
Hey,
Coriolis' PCB layout spurred me to do my own dual version last week (sorry, I don't mean to steal any of your thunder by adding my own layout!)
I've always been very keen on such EnvGens and this is a really great design - I'm gonna build a stack myself! I very much like compact layouts with pots mounted on board and this design really lent itself to a dual version. Its laid out for 16mm Alpha pots spaced by 0.8" (20.32cm) so fits nicely into my Frac system (or Eurorack).
I added LED indicators using standard transistor buffers and also included an extra switchable timing cap for each EG - I've yet to do my final value selections on these, but if you use holders you can always test things and select your favourite values (Ian's original schem specified 4u7)
I've done it up as a PDF with schematic redraw, parts placement and press'n'peel image. Of course its possible that the exact size of the PCB image may get scewed off somehow, so I'm attaching a hi-res TIF of the PCB too.
Enjoy! Many thanks to Ian for the great circuit!
| Description: |
| PDF Build Doc for Fritz Dual AD/AR Env Gen - with redrawn schematic, parts placement and press'n'peel image |
 Download (listen) |
| Filename: |
FritzDualADAR_BuildDoc.pdf |
| Filesize: |
423.13 KB |
| Downloaded: |
2346 Time(s) |
| Description: |
| Press'n'peel image at 300dpi (tif file) - just in case the pdf one gets mis-scaled or something... |
 Download (listen) |
| Filename: |
Fritz_Dual_AD_AR_PCBImage.tif |
| Filesize: |
2.34 MB |
| Downloaded: |
1522 Time(s) |
_________________ http://www.bugbrand.co.uk
http://www.bugbrand.blogspot.com |
frijitz
Audio files: 54
Posted: Sun Mar 02, 2008 1:09 pm Post subject:
Good job!
Ian |
6079smith
Joined: Jan 18, 2007 Posts: 95 Location: Mark of the Dane
Posted: Sun Mar 02, 2008 1:37 pm Post subject:
| Yes, thanks for these, guys. |
Coriolis
Posted: Mon Mar 03, 2008 4:34 am Post subject:
Ah yes! That's the stuff Tom!
If you didn't have 2 units in one layout, I'd use yours instead of my own, but I have different plans for my panel layout...
I should mod mine for on-board pots as well, it's the obvious thing to do...
C |
Sebo
Posted: Mon Mar 03, 2008 12:43 pm Post subject:
Thanks Coriolis, Bugbrand, and of cours Ian!!!
I think I would build a few of this in the future.
But lately my to-do list is growing too fast. _________________ Sebo
My Music:
https://www.facebook.com/cosaquitos/ |
richardc64
Audio files: 26
Posted: Mon Mar 03, 2008 2:48 pm Post subject:
Am I the only one who can't see the gifs and tif in this thread? I see empty attachment boxes. _________________ Revenge is a dish best served with a fork... to the eye |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Mon Mar 03, 2008 3:35 pm Post subject:
| The .tif image does not show for me. If I click on it, it does load in a new window and is viewable. The .gif images are viewable for me natively. |
bugbrand
Posted: Wed Mar 05, 2008 3:06 am Post subject:
Cool and thanks for thanks and thanks to Ian! haha
Hey, so is the .tif not so much use to people? I could easily convert it to something else more standard - I just thought tifs were nice resolution.. Actually, I daresay jpeg would be just fine..
Ok, here it is again - 72dpi one and 600 dpi (I always wonder if that'd get resized? depends on software etc - confusion!)
| Description: |
| Fritz dual AD/AR Press'n'peel image JPEG 72DPI |
| Filesize: |
16.85 KB |
| Viewed: |
52583 Time(s) |
| Description: |
| Fritz dual AD/AR Press'n'peel image JPEG 600DPI |
| Filesize: |
329.16 KB |
| Viewed: |
968 Time(s) |
richardc64
Audio files: 26
Posted: Wed Mar 05, 2008 8:58 am Post subject:
| bugbrand wrote: | | Hey, so is the .tif not so much use to people? |
Well, I don't know about that. I wasn't suggesting tifs aren't useful. My browser, Maxthon, doesn't like this thread, for some reason. I can see and click on gifs, jpgs, etc. in other threads, but in this one the only thing clickable is the pdf.
Strange.
Stranger. I just found that this thread acts normally in Opera and -- of all things -- IE! _________________ Revenge is a dish best served with a fork... to the eye |
loss1234
frijitz
Audio files: 54
Posted: Tue Jul 08, 2008 5:21 pm Post subject:
| loss1234 wrote: | | does anybody know how to increase the release time of this circuit? i like really long release times. |
My current recommendation is to use larger pots. 250k log for attack and 1M log for decay/release. You could up the decay/release pot to 2M, if resolution at the low end is not important to you. Also, you will get longer tails if the Truncate switch is in the closed position (no truncation). You can also increase the timing cap if you like. This will increase all times.
Ian |
synthmonger
Posted: Tue Jul 08, 2008 5:35 pm Post subject:
| Anything against using a 500k-2M pot for attack? |
frijitz
Audio files: 54
Posted: Tue Jul 08, 2008 5:36 pm Post subject:
Re: PCB layout for Ian Fritz' AD/AR EG Subject description: ..built one and it works |
Just as a heads up to anyone interested in this module, a new version is in the works. This will include one EG and the Delayed Monostable auxilliary circuit. All four pots will be board-mounted for a MOTM panel configuration. The proto board is here, and I hope to stuff and check it with a week or so. If it's OK, the final board will be available through bridechamber.com.
Ian |
RF
Audio files: 28
Posted: Tue Jul 08, 2008 5:53 pm Post subject:
Good news, Ian. Thanks
The Bridechamber Threeler board was great. |
frijitz
Audio files: 54
Posted: Tue Jul 08, 2008 6:41 pm Post subject:
| synthmonger wrote: | | Anything against using a 500k-2M pot for attack? |
No, nothing against it if you need long attack times. The only issue will be that you will loose resolution at the low end.
Ian |
Coriolis
Posted: Wed Jul 09, 2008 11:35 am Post subject:
Hmm...sounds interesting. I've been having trouble with my veroboard version of the delayed pulser (magic smoke coming out!), so maybe I should just spring for a couple of these boards to finally get that module done!
Will there be boardmounting of pots?
C |
