Anyone used the Doepfer Pocket Dial with the G2?
Page 1 of 1 [25 Posts]
Audio files: 224
PostPosted: Fri May 07, 2004 7:26 am    Post subject: Anyone used the Doepfer Pocket Dial with the G2? Reply with quote  Mark this post and the followings unread
Has anyone used the Doepfer Pocket Dial with the G2? Seems like a natural.
http://www.doepfer.de/home_e.htm
This is different from the Pocket Control which uses pots, not endless rotary encoders.
Nodular
G2 patch files: 7
PostPosted: Mon Sep 05, 2005 2:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd like to know too...
3phase
G2 patch files: 141
PostPosted: Mon Sep 05, 2005 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
i dont think the G2 understands incremental controlers... Or?
but..
maybe it should.. at least the engine would benefit from that.
jksuperstar
G2 patch files: 18
PostPosted: Mon Sep 05, 2005 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, incremental controllers would be nice, you could have as much resolution as you wanted, instead of 7bits as per MIDI CC#s. I have an old Peavey StudioMix, which only uses NRPNs, meaning I need a translator somewhere to use it. NRPNs inthe G2 would be helpful for MIDI processing.
But MOSC is right, that little box looks like a match for the "empty" space on the G2's (I'm always looking for more things to put there!).
gal
G2 patch files: 10
PostPosted: Mon Sep 05, 2005 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
It definitly understands incremental controllers. I used it a while ago with Cubase SX. But isn't there more than one method of incremental controller communication?
Best would be to check out the manual for detailed information about communication methods ( http://www.doepfer.de/pdf/pd_man.pdf )
good luck
gal
note Blue Hell : edited post to make link clickable
Audio files: 297
PostPosted: Mon Sep 05, 2005 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Some creative use of flipflops and or s&hs would give you NRPNs on the G2 I'd say.
Kassen
PostPosted: Mon Sep 05, 2005 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rob already did that. It's just data and the NM is turning complete except for that pesky "infinite" bit so...
I'd say native NRPN support should immeditaly be on the "to do" list, but who am I?
Kassen
sebber
G2 patch files: 33
PostPosted: Mon Sep 05, 2005 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
What are NRPNs? Confused
Audio files: 297
PostPosted: Mon Sep 05, 2005 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
For some info on NRPN's see http://www.philrees.co.uk/nrpnq.htm
A summary :
It is a way to have finer detailed control over more parameters through MIDI. Normally with CCs you get 128 value steps for 120 controllers, with NRPN's you can get 16384 steps for I think 16384 controllers.
It works by first selecting through a special CC sequence a controller to manipulate and then sending values for that specific controller through some other CC messages. When you want to control another parameter you first have to select that one.
The price to be payed is some protocol overhead, meaning that more time is needed to control parameters in this way. Fast changing parameters in practice need less detail in their control, so those could be dealt with by normal CCs.
Doing it yourself :
An NM implementation would need some storage elements (S&H's) to remember values in and some logic to get values into that storage depending on the MIDI CC sequence seen. o not use all your resources for NRPNs only you would have to limit yourself to some parameters that you can to control in this way.
I of course agree that it would be nice to have this built in as a system feature, but when you really need it /now/ for some parameters you could build it yourself.
deknow
PostPosted: Mon Sep 05, 2005 9:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
jan, would that be possible for pitchbend data? i can't quite picture the whole concept.
deknow
jksuperstar
G2 patch files: 18
PostPosted: Mon Sep 05, 2005 10:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pitchbend's use a dedicated MIDI command (3bytes total) to transmit the 14bits of pitchbend data.
NRPN's use a sequence of 4 commands (2 for address and 2 for data) (12 bytes total) to allow the 14 bits of data transfer. They are like the CC expansion for undefined things, much like sysex allowed for undefined things. Sysex was intended for non-realtime control, whereas NRPNs are FOR real time control.
Pitchbend *could* be sent over NRPNs, but unless you have more than 1 pitchbend per MIDI channel, it'd be a waste of MIDI Bandwidth. It would be perfect for more than 1 pitchbend within a MIDI channel (Poly pitchbend?)
Kassen
PostPosted: Tue Sep 06, 2005 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
For some info on NRPN's see It is a way to have finer detailed control over more parameters through MIDI. Normally with CCs you get 128 value steps for 120 controllers, with NRPN's you can get 16384 steps for I think 16384 controllers.
Yeah, that sounds right. Of cource it doesn't realy matter that you can adress that many parameters because MIDI is so slow and this stuff has a lot of overhead so morphs over 16K+ parameters will take quite a while....
Kassen
soundklang
G2 patch files: 6
PostPosted: Tue Apr 01, 2008 11:04 am    Post subject: emulating incremental controls with the g2 Reply with quote  Mark this post and the followings unread
hi,
http://electro-music.com/forum/topic-25262.html shows a patch that emulates an incremental controller with a frontpanel knob. it also allows for independently assign and name a knob and a button to the frontpanel.
buzzr
PostPosted: Tue Apr 01, 2008 6:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I use the pocketdial with the G2 and it works great.
We are currently designing a midi controller like the Pocketdial but with better encoders (smoother) and the encoders also have switches built into them.
So the controllers will be smaller then the pocketdial, have 16 encoders that will be able to use four of the switches on the encoders to switch between the banks. The rest of the encoder switches will be used as cc. We are thinking that we might also be able to custom program for people who want something different.
The controller box will also have 2 inputs for outside sensors, maybe 4, we are still working this out. So... the list
16 encoders with switches
2 to 4 inputs for sensors
USB and MIDI out
and smaller then the pocketdial.
And no, it's not built from midibox.org designs.
Not sure when we are going to have these done as we are running into problems with the code (Amtel Chips)
www.buzz-r-electronics.com
Audio files: 224
PostPosted: Wed Apr 02, 2008 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice web site. Very interesting pics of DIY synths. thumb up
puggo
G2 patch files: 4
PostPosted: Wed May 13, 2009 1:38 am    Post subject:   Reply with quote  Mark this post and the followings unread
hello!
here a g2 newbie
would like to know if anyone here uses the "classic" pocket control to tweak the engine. I used it years ago with my first micromodular and worked for me...but surely I touched some of the backside pins and loose that generic preset. Don´t know if ithis first pocketc is suitable for my engine (it seems it receives control from the pocket, but can´t assign the controls properly on the editor)
tonight I´ll try with some "generic" presets from the pocket I´ve seen at the manual (the "masterchannel" ones)
all the best,
pug
buzzr
PostPosted: Wed May 13, 2009 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, I have had both the pocket dial and the pocket control. Unfortunately the G2 has a bunch of midi channels taken and you cannot use them. Which makes it difficult when you have unprogramable midi controllers like the Pocket Dial and Control.
Here is the list:
Unusable MIDI CC#'s
0
1
7
11
17
18
19
32
64
70
80
96
97
121
123
buzzr
PostPosted: Wed May 13, 2009 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Faderfox is also this way. So, any small midi controller it seems is not really suited.
egw
G2 patch files: 8
PostPosted: Wed May 13, 2009 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
The Korg Nano has assignable controls.
Also the Behringer midi controllers, but they're a bit larger.
www.gregwaltzer.com
puggo
G2 patch files: 4
PostPosted: Wed May 13, 2009 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is the list:
Unusable MIDI CC#'s
0
1
7
11
17
18
19
32
64
70
80
96
97
121
123
thanks for the help!
I´ll try it tonight. (crossing fingers) Rolling Eyes
best,
pug
buzzr
PostPosted: Wed May 13, 2009 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, yes the nano series. These are quite fragile unfortunately...
egw
G2 patch files: 8
PostPosted: Thu May 14, 2009 5:37 am    Post subject: Reply with quote  Mark this post and the followings unread
The Peavy pc1600x is very sturdy and completely programmable - not much bigger than the nano, but more expensive. No knobs, only buttons and sliders. The buttons don't light up to indicate on/off in toggle mode, which is one thing I like about the nano.
www.gregwaltzer.com
grimley
G2 patch files: 9
PostPosted: Fri May 15, 2009 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Haven't seen the Pocket Dial, but I did use the Doepfer Pocket Electronics to build this thing which fits perfectly on the right side of my G2:
Custom joystick controller
 Filesize:  19.37 KB
 Viewed:  12397 Time(s)
Doepfer Pocket Electronics + G2
 Filesize:  153.33 KB
 Viewed:  170 Time(s)
davep
Audio files: 10
G2 patch files: 73
PostPosted: Fri May 15, 2009 11:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoa! What the hell is that?
Dave Peck
grimley
G2 patch files: 9
PostPosted: Fri May 15, 2009 11:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
A bunch of radio shack knobs (not endless encoders) and switches and 2 Doepfer joysticks (with springs removed) connected to a Doepfer Pocket Electronics kit, stuffed into a Lacie drive enclosure plastered in Elektron stickers!
http://www.doepfer.de/pe.htm
