 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
Nintendo DS
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [6 Posts]
jksuperstar
G2 patch files: 18
PostPosted: Tue Mar 31, 2009 5:48 pm    Post subject: Nintendo DS
Subject description: Touch, Wifi, dual ARM processors, and two expansion ports
Ok, so this isn't an apple product, but sits in the exact same class, and much of the development work that went into the Nintendo DS as a music machine was then ported to the iPhone later on.
I'm in the process of adding a hardware midi port, rather than wifi, so I can avoid having a computer around all the time. It's through an SPI port, so easy to interface to, and there's cheap hardware available to do this.
Links:
http://www.nintendo.com/ds
DSMI (offers MIDI and OSC via WiFi)
http://dsmi.tobw.net/forums.html?cat_id=1
Hardware Interface (debug, MIDI, SD card storage) (the DSMI lib above supports this card)
http://www.electrobee.com/dserial-edge-p-45.html
Tools for writing your own programs
http://www.devkitpro.org/
Technical Reference:
http://www.bottledlight.com/ds/forums.html
Nintendo DS
 Filesize:  10.91 KB
 Viewed:  5604 Time(s)
jksuperstar
G2 patch files: 18
PostPosted: Tue Mar 31, 2009 10:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, almost forgot the really good stuff:
http://remaincalm.org/forums.html/ds-music-apps
iPassenger
G2 patch files: 78
PostPosted: Tue Apr 07, 2009 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
jksuperstar,
Will this DSMIDIWifi Server convert OSC data into Midi for me on my pc?
R.
iP (Ross)
jksuperstar
G2 patch files: 18
PostPosted: Tue Apr 07, 2009 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Not that I know of. This is what I've put together, though it may not be accurate:
Supposedly OSC doesn't need DSMIDI at all, since it is already a network protocol, and TX and RX machines already know how to construct and deconstruct OSC packets, and use the same port#. DSMIDI (the client on your computer) just talks it's own midi packets. However, the DSMIDI library provides the OSC support to applications.
I'm notsure if it's RTP-MIDI compatible (RTP MIDI is an open standard to transmit MIDI over LAN, which Apple uses for midi over lan).
http://www.cs.berkeley.edu/~lazzaro/rtpmidi/
BobTheDog
Audio files: 32
PostPosted: Tue Apr 07, 2009 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
iPassenger wrote:
jksuperstar,
R.
On a PC it seems its a bit DIY, have a look at PureData http://code.google.com/p/oscemote/wiki/OSCemotePureDataTutorial
MAX, Reaktor or Bidule will also let you do this sort of thing.
iPassenger
G2 patch files: 78
PostPosted: Tue Apr 07, 2009 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers for the responses, this is as I thought, nice if there was something a bit simpler that required less seperate programs (and thus pc resources).
Might try yr dsmidi thing though. Smile
iP (Ross)
