 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
48 Bands Vocoder
Page 1 of 1 [17 Posts]
mother misty
G2 patch files: 130
PostPosted: Sun Jul 11, 2004 11:24 pm    Post subject: 48 Bands Vocoder Reply with quote  Mark this post and the followings unread
48 (3x16) Bands Vocoder. Good for robotic voices.
48 Bands Vocoder.pch2
48 Bands Vocoder
 Filename:  48 Bands Vocoder.pch2
 Filesize:  3.27 KB
 Downloaded:  3116 Time(s)
48BV-VAR2.mp3
Sound Example 48 Bands Vocoder (variation 2)
 Filename:  48BV-VAR2.mp3
 Filesize:  811.69 KB
 Downloaded:  1920 Time(s)
General Elektrick
PostPosted: Mon Jul 12, 2004 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
thumb up
Sounds very good!
Best,
General Elektrick
Fozzie
G2 patch files: 49
PostPosted: Mon Jul 12, 2004 1:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool lyrics there, too Very Happy
General Elektrick
PostPosted: Mon Jul 12, 2004 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Question Question Question
Lyrics Question Question Question Question
Question
Fozzie
G2 patch files: 49
PostPosted: Mon Jul 12, 2004 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah, but you have to understand Dutch (better: Flemish) and listen real carefull. It's the mp3 of course, and possibly 'text' is a better word than 'lyrics', but it's funny.
PostPosted: Mon Jul 12, 2004 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked Very Happy
Hehe... ok... so now you really have to tell us what the voice says! Very Happy
Flickr
Fozzie
G2 patch files: 49
PostPosted: Mon Jul 12, 2004 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
...........[I cannot make out the first word] those leaves then, until they withered, or, they didn't appear fresh [anymore]. And so you notice that the flower's energy had transferred into the water. And how do you determine, as therapists, what kind of [?]blossom is the best match to the people? For me, the best way is.... talking to the people. [Etc etc etc etc].
Hard to translate. Just some silly conversation, but I think it's very funny.
PostPosted: Mon Jul 12, 2004 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
Flickr
BobTheDog
Audio files: 32
PostPosted: Thu Sep 15, 2005 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I have an expanded G2 keyboard and when I load this I Get "No Voices".
Anyone any ideas why?
Andy
PostPosted: Thu Sep 15, 2005 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
The patch was made over a year ago, so on some older software version, very likely. Sometimes when new software is released the DSP details for modules will change, so when a certain patch is on the edge, DSP wise, it can over it using the new software.
Usually such a patch can be made working again by deleting some stuff, or by replacing it with cheaper modules. Sometimes that's very hard though.
BobTheDog
Audio files: 32
PostPosted: Thu Sep 15, 2005 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jan,
Thanks for the info it's put my mind to rest as I thought my expansion board was not working correctly.
Andy
PostPosted: Thu Sep 15, 2005 11:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Andy,
In case you are still worried:
you can easily check if the expansion is working by making a patch that uses over 50% (but less than 100%) of one of the dsp resources. That patch should give you 4 voices on an unexpanded, 8 voices on an expanded G2 (proveded its the only active patch).
It does not have to be a working patch, just throw in some expensive modules, like a vocoder, for quick results.
When you get no voices at all for a single patch that means you (or someone else in this case) exceeded some DSP limit somewhere in that patch.
BobTheDog
Audio files: 32
PostPosted: Fri Sep 16, 2005 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
HI Jan,
Thats a good tip, I did this and got 8 so it looks ok.
When I load the 48 band vocoder I get a VA reading of 100.0.
I changed the OSCA that feeds into the brightness module to a OSCC module and the VA goes down to 98.6 and it now works.
I will keep an eye on the VA setting from now on.
I am gradually getting my head around the G2, its a versatile machine are all clavia machines this well designed?
All the best and many thanks for your help.
Andy
mother misty
G2 patch files: 130
PostPosted: Fri Sep 16, 2005 1:25 am    Post subject: Reply with quote  Mark this post and the followings unread
euhm... I'm a bit confused here scratch
Do you mean that this patch doesn't work on
an expanded G2 with OS 1.32?
(I still haven't upgraded to v1.32...)
davep
Audio files: 10
G2 patch files: 73
PostPosted: Fri Sep 16, 2005 5:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm confused about this patch. It seems to me that although it's splitting the audio into three bands (hi/med/lo) via the multimode filter, it's just sending the results through three instances of the standard 16 band vocoder. Is it really 48 separate frequency bands? Or are there just three bands at 20 Hz, three bands of 60Hz, etc., with two out of each group of three bands not really doing anything (the 20Hz bands in the vocoders connected to the mid out & hi out won't get any signal, etc.)?
Dave Peck
BobTheDog
Audio files: 32
PostPosted: Fri Sep 16, 2005 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
No it doesnt work on my expanded G2 ver 1.32.
If I change the OSCA to an OSCC it works though.
Andy
mother misty
G2 patch files: 130
PostPosted: Mon Sep 19, 2005 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Andy
Damn, didn't know that Sad i'm still one v1.30
it's already the 2nd time an OS upgrade requires a higher DSP-load!
when you read the "what's new" in the release notes it says
4. What's new in V1.32
Version 1.32 is a minor update that solves two issues with version 1.30.
One is that the Mac OS X version was crashing when running together with
some other applications and with some MIDI drivers.
The other is that the Note Detector would trig on the local keyboard even
if the slot was not assigned to receive keyboard events.
but it seems they've changed more, because this patch works on v1.30 and not on v1.32 scratch
