 Forum index » Clavia Nord Modular » G2 Patches - Completed » Fantasy
Triangle Wave fun
Page 1 of 1 [5 Posts]
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sun Feb 11, 2007 4:01 pm    Post subject: Triangle Wave fun Reply with quote  Mark this post and the followings unread
Hi all,
This started as a bit of an experiment to see how many different sounds I could get by messin' with a single triangle wave. Quite a few, it turns out.
First the triangle is sent through a pair of shapers and a crossfader to gradually change between log & exp shapes. Then an LFO gets mixed with the wave for a slow pos-neg DC offset before sending it through a pair of wave wrappers and another crossfader. Normally, you can't 'hear' DC offset, but in this case the DC offset affects how the wrappers alter the waveform. Then a second pair of shapers to process the result of all this, and a compressor to smooth out the level.
All of the LFOs involved are running at different rates, so the result is a waveform that is constantly changing in several different ways at different rates. Note that some of the variations have the LFOs in mono mode (all voices change the same way at the same time) and other are in poly mode (different voices don't sound the same).
Another variation on this idea is to use a single EG instead of the LFOs for controlling all the sweeps, with a bunch of Pos/Neg switches to control the EG polarity at each mod input so you can have the wrappers sweep up while crossfader moves 1>2, or wrappers sweep down while crossfader moves 2>1, etc.
WrapOneOsc.pch2
Lots of timbres from one triangle wave.
 Filename:  WrapOneOsc.pch2
 Filesize:  2.56 KB
 Downloaded:  1005 Time(s)
Dave Peck
3phase
G2 patch files: 138
PostPosted: Sun Feb 18, 2007 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
makes nice noises on a square wave...
i wonder how this patch would sound on the nm1... i guess the sound of the aliasing noises is the biggest difference..
wraponeosc_1192.pch2
 Filename:  wraponeosc_1192.pch2
 Filesize:  3.14 KB
 Downloaded:  839 Time(s)
eposk
PostPosted: Sun Feb 25, 2007 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
great patch!!!
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Sun Feb 25, 2007 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's a good idea dave, I too like to put some limits on my patches. Here is my noisy take on the simple triangle wave.
/Dasz
TreeAngle_DZ.pch2
 Filename:  TreeAngle_DZ.pch2
 Filesize:  2.92 KB
 Downloaded:  855 Time(s)
http://www.clavia.se/misc/users/daszgarncarz.htm
http://haagenlive.blogspot.com/
davep
Audio files: 10
G2 patch files: 73
PostPosted: Fri Mar 02, 2007 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Check this out - replace that "A" osc with a "C" osc, which has hard sync and FM inputs. Set it to either SINE or TRIANGLE. Use the "A" osc as a sync master & FM source for the "C" osc only, not as a direct audio source. Try various waveforms. Now add a couple more UNIpolar triangle LFOs, one to sweep the pitch of the hardsync'd "C" osc, one to control a VCA that varies the amount of FM from "A" osc to "C" osc. Lots more cool sounds....
Dave P
Dave Peck
emSynth
