Lorentz thingy
Page 1 of 1 [11 Posts]
Audio files: 218
G2 patch files: 319
PostPosted: Sat Feb 26, 2005 10:41 am    Post subject: Lorentz thingy Reply with quote  Mark this post and the followings unread
On some other thread I spotted someone with an interesting sig:
Code:
      dx/dt = delta * (y - x)
      dy/dt = r * x - y - x * z
      dz/dt = x * y - b * z
Which turned out to be a Lorentz attractor thingy, more info about this can be found at :
http://www.enseeiht.fr/hmf/travaux/CD9899/travaux/optmfn/hi/99pa/hydinst/report03.htm
The attached patch is an implementation of this sig applied to some simple bleeps.
To start the process with a random seed the button on the red module must be clicked. When the pattern gets boring another click will start some other sequence. Diffent values can be set for the delta, ra nd b parameters, this is a bit critical - you might want to try to change the integration constants as well in the F(d/dt) modules.
Jan.
lorentz.pch2
An implementation of the Lorentz attractor.
 Filename:  lorentz.pch2
 Filesize:  2.19 KB
 Downloaded:  1466 Time(s)
Audio files: 218
G2 patch files: 319
PostPosted: Sat Feb 26, 2005 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
And a Rossler thingy, from the same url I mentioned above.
This one uses :
Code:
      dx/dt = -y - z
      dy/dt = x + Ay
      dz/dt = B + xz - Cz
It's different, and harder to get interesting things out.
Jan.
Rossler.pch2
Rossler attractor
 Filename:  Rossler.pch2
 Filesize:  2.51 KB
 Downloaded:  1413 Time(s)
Audio files: 218
G2 patch files: 319
PostPosted: Sat Feb 26, 2005 5:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
And a slightly more interesting example of the Lorentz patch.
I added some knob assignments for easier control for keyboard owners, the Rossler patch has the same knob assignments btw.
jan.
lorentz.pch2
A slightly more interesting Lorrentz example
 Filesize:  2.57 KB
 Downloaded:  1441 Time(s)
inversekinematics
PostPosted: Sat Feb 26, 2005 5:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
jan.
sweet! very cool Smile
(dx/dt=delta*(y-x))(dy/dt=r*x-y-x*z)(dz/dt=x*y-b*z)
Audio files: 218
G2 patch files: 319
PostPosted: Sat Feb 26, 2005 6:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah there is the sig I meant, I somehow knew I'd get you into my strange attractor :-)
(delta, r, b) = ( 54, 43, 36) gives a very nice pattern, had it running for quite a while now. And meanwhile I've been looking for interesting four dimensinal sets of non linear differential equations having strange attractors - do you happen to have any references ?
Jan.
ps: a nice introduction I think, and very readable, is : http://amath.colorado.edu/faculty/jdm/faq.html
inversekinematics
PostPosted: Sat Feb 26, 2005 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah there is the sig I meant, I somehow knew I'd get you into my strange attractor Smile
Jan.
i used to develop flash sites with those equations, www.logotype.se, but the webserver is not online right now due to re-install... but i'll let ya know when its up again... would really like to use that patch/export sound... would be cool to have a realtime flash app, with sound (not realtime sound tho)
Audio files: 218
G2 patch files: 319
PostPosted: Sat Feb 26, 2005 8:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please do eagarding letting me know, and please do regarding flash app & sound as well.
Jan.
PostPosted: Sun Feb 27, 2005 3:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Can´t flash output midi these days too? That would pave the way for a n.dimentional "noodlesequencer" with a "timeline" that would turn and twist over the schreen.
Audio files: 143
PostPosted: Mon Feb 28, 2005 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is very very cool. Cool
I'm trying to catch up on posts after being away for 2.5 days. I'm going to come back to this. Thanks, Jan. I dig this.
Audio files: 218
G2 patch files: 319
PostPosted: Mon Feb 28, 2005 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Already thought you would like this Howard, but be warned it's not really easy to get nice things out - percussive might be the way go.
I didn't feel sure enought to post this to the snippets section - I mean the request you posted a while ago for chaos patches.
Anyway, hope you enjoyed your holiday :-)
Jan.
JLS
Audio files: 27
G2 patch files: 278
PostPosted: Sun Apr 29, 2007 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Basic Lorenz attractor
same like BlueHells algo but other patching ( self clock system )
Smile
 Filesize:  19.81 KB
 Viewed:  11856 Time(s)
Basic-Lorenz.pch2
 Filename:  Basic-Lorenz.pch2
 Filesize:  2.21 KB
 Downloaded:  1002 Time(s)
Sorry my bad English Smile
http://jlswbs.blogspot.com
http://jlswbs.wordpress.com
http://jls.wbs.cz
