New Up/Down Counter
Page 1 of 1 [5 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Thu May 31, 2007 4:39 am    Post subject: New Up/Down Counter
Subject description: counter revamped
Here's a streamlined new version of my counter circuit.
Originally I had used feedbacked S-Flipflops as one-sample pulse generators. However, I've found out now that the logic pulse module also produces exactly one sample, and is more efficient output-wise.
This circuit has following controls possibilities:
AMOUNTS -Sets separate amounts for upwards and downwards counting.
START -Sets the start value
See the attached demonstration modules to see how to implement the logic gates for starting and counting.
This fully-equipped counter circuit uses only 1,8 cycles/3,9 memory. If you only need a simple upwards counting circuit with reset to zero, you can simply remove the unnecessary modules (START constant module, DOWN logic pulse) and replace the dual mixer with a single one, getting it down to 1,0 cycles/2,3 memory. How good is that Smile?
NewCounter TK.pch2
Improved counter circuit with separate up/down counting ranges and start value (1,8 cycles/3,9 memory)
 Filename:  NewCounter TK.pch2
 Filesize:  1.32 KB
 Downloaded:  946 Time(s)
3phase
G2 patch files: 141
PostPosted: Thu May 31, 2007 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
That is very cool..i just dont understand why the pulses build up in value...
That is quite some discovery...
Tim Kleinert
G2 patch files: 236
PostPosted: Thu May 31, 2007 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
The pulses add up because the whole circuit is in 100% feedback.
3phase
G2 patch files: 141
PostPosted: Thu May 31, 2007 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
ah ..sure..have overseen the connection to the feedtru input of the mixer...
nice trick...pretty usefull circuit... and quite economic...
i just added for my own purposes an upper/lower border...
i just ad the modded patch..ok?
if not i can remove it
a little update
newcounter__tk1b.pch2
 Filename:  newcounter__tk1b.pch2
 Filesize:  1.49 KB
 Downloaded:  952 Time(s)
3phase
G2 patch files: 141
PostPosted: Thu May 31, 2007 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I just realized something regarding buildingblocks... its pretty important to copy the settings into all variations otherwise some vital settings might be lost when inserting a block into another variation... seems somebody should push the parameter copy into all variations wish on the list a bit more...instead of the up/down counter Wink
