n-inputs/n-outputs randomizer setup
Page 1 of 1 [22 Posts]
audible
PostPosted: Sun Jun 03, 2007 4:59 pm    Post subject: n-inputs/n-outputs randomizer setup
Subject description: Big noob, please help
I'm sort of new to modular thinking... Steep learning curve, but I'm eager to improve. Can anybody tell me which modules I need to achieve this?
I'd like to have a setup with n inputs (control signals) connected to n outputs. At the clicking of a switch, the outputs would interchange at random.
Maybe a diagram shall clarify it...
 Filesize:  6.62 KB
 Viewed:  24570 Time(s)
Audio files: 213
G2 patch files: 319
PostPosted: Sun Jun 03, 2007 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome audible.
I can't patch right now ... hope to think on it later ... when nothing happens here please remind me in a few days.
It should take a couple of multiplexers and demultiplexers and some adding of constants to a random signal and a modulo circuit, or something like that. Might get out of control for large N ... in terms of resource usage ...
Audio files: 213
G2 patch files: 319
PostPosted: Mon Jun 04, 2007 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not so easy Very Happy
I can make a random shifter like thing ... everything I come up with for more complicated permutations gets way out of control for module usage.
Anyway, here is the shifter, and that's pretty expensive already.
rs-002.pch2
control signal shifter
 Filename:  rs-002.pch2
 Filesize:  2.98 KB
 Downloaded:  1219 Time(s)
G2 patch files: 625
PostPosted: Mon Jun 04, 2007 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Do the connections need to be 1:1 exclusive?
Audio files: 213
G2 patch files: 319
PostPosted: Mon Jun 04, 2007 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's what I assumed, I broke my head on exclusion stuff Very Happy
iPassenger
G2 patch files: 78
PostPosted: Tue Jun 05, 2007 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
It does seem that the exclusivity is the problem (it forces the need for increased control over the random element), unless you can find a way that doesn't use MUXs at all?
Seems a lot more difficult than you might imagine.
iP (Ross)
Audio files: 370
PostPosted: Tue Jun 05, 2007 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Try this. it's a lot of little 2-2 switches. It needs a sample/hold in there, but you get the idea. For better scrambling, add more columns (have to catch the bus, if you need more info, ask).
/Stefan
sbt_shufflepatch.pch2
 Filename:  sbt_shufflepatch.pch2
 Filesize:  4.82 KB
 Downloaded:  1106 Time(s)
Audio files: 370
PostPosted: Tue Jun 05, 2007 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, I updated the patch to shuffle 8 inputs, and attached a little sketch showing the principle. Note that although in the new patch (the old was a little buggy) e.g. input 1 may be routed to any output, there is a greater chance that it will be routed to output 1 or 2, since there are more paths to those outputs than the others. Maybe the switching can be tweaked so the spread is more even?
As can be seen in the sketch, only three columns are needed for six inputs, and two columns for four inputs. Also note that I only used the muxes here to show the values visually, when using this replace the constant modules with input, and the muxes with output.
Still a little bit cheaper than Jan's version on the cycle side, I think, although bigger and consuming more memory. Another downside is that I don't know how to reshuffle without having a short moment where all inputs are routed directly to the outputs (random triggers only stay up as long as there is a live value at the Clk input).
This is fun! Very Happy
/Stefan
Switch illustrations: 8 to 8, 6 to 6 and 4 to 4
 Filesize:  64.07 KB
 Viewed:  394 Time(s)
sbt_shufflepatch_8.pch2
8 to 8 shuffle
 Filename:  sbt_shufflepatch_8.pch2
 Filesize:  4.67 KB
 Downloaded:  1214 Time(s)
Audio files: 213
G2 patch files: 319
PostPosted: Tue Jun 05, 2007 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maddening Twisted Evil
3phase
G2 patch files: 138
PostPosted: Tue Jun 05, 2007 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
a primitiv solution for only 3 input and no propper random...
bit its the cheap and dirty way when oly 3 inputs are enough
rando rout 3.pch2
 Filename:  rando rout 3.pch2
 Filesize:  2.06 KB
 Downloaded:  983 Time(s)
Audio files: 213
G2 patch files: 319
PostPosted: Sat Jun 09, 2007 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
A bit late, but looking at some notes still laying on my desk I came to realize that this actually is equivalent to a basic programming exercise ... how to place eight queens on a chess board in such a way that they can't capture each other.
Usually this is solved using (recursive) backtracking, i.e try something and when it fails roll back and try something else, repeat until completed or failed.
There is a straightforward solution as well, pick any crossing you'd like to start with and then move 2 steps either horizontal or vertical followed by one step vertical or horizontal, in chess terms: the way the knight moves.
Not that this brings a solution in the form an actual patch any closer, but thought it to be interesting nevertheless.
Alse see http://en.wikipedia.org/wiki/Eight_queens_puzzle
Falk
G2 patch files: 29
PostPosted: Sat Jun 09, 2007 10:49 am    Post subject: Better version
Subject description: Lower CPU and memory usage for permutation of 8 signals
Hello audible and everyone.
I took Antimons patch and optimized it a bit.
I knew that computer science degree would come in handy some day Very Happy
/Falk
falk_shuffle8.pch2
A random permutation of 8 signals
 Filename:  falk_shuffle8.pch2
 Filesize:  3.42 KB
 Downloaded:  835 Time(s)
Audio files: 370
PostPosted: Sun Jun 10, 2007 9:41 am    Post subject: Re: Better version
/Falk
Clever! Very Happy I keep forgetting about the usefulness of the inverter.
Value Switch 2-1: D'oh! I should try to learn about all of the modules.
Thanks.
/Stefan
audible
PostPosted: Sun Jun 10, 2007 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for all the answers, I thought this would be easier...
Though a couple of the previous patches seem to work with what I was planning, I fail to fully understand any of them... As stated above, I'm a noob but I hope someone else might find all this useful and worth of study.
It's great to provide a good source of head-scratching to you all...
Audio files: 213
G2 patch files: 319
PostPosted: Sun Jun 10, 2007 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing got any more of those ?
Falk
G2 patch files: 29
PostPosted: Wed Jun 13, 2007 12:44 pm    Post subject: New try, and this a puzzler Reply with quote  Mark this post and the followings unread
You can always ponder the use of the NOR gate in this patch.
It is an 8-in/8-out shuffle that can be also be repatched to work as 7/7 down to 3/3 (old patch can only be 2/2, 4/4, 8/8, 16/16 etc)
It is a 0.5% cheeper in CPU and does not rise in CPU usage if audio rate inputs are used (unlike old patch where CPU goes up).
The Injector feeds the shift registers with 8 values that will each select a different input on the Mux8-1 Out N modules. The order is then incrementally scrambled by the clocked random module (Mix source).
Con: Can not be expanded above 8/8
Con: Before you press the sample button, all outputs come from input 1
Con: You can't really clock the sample button faster than 31.25 Hz (if I got the math right) and still expect a really random shuffle. Laughing
Enjoy
/Falk
falk_shuffle_8_v2.pch2
8-in/8-out shuffle based on shift registers
 Filename:  falk_shuffle_8_v2.pch2
 Filesize:  1.99 KB
 Downloaded:  866 Time(s)
Audio files: 213
G2 patch files: 319
PostPosted: Wed Jun 13, 2007 2:02 pm    Post subject: Re: New try, and this a puzzler Reply with quote  Mark this post and the followings unread
I'm afraid I could use a little help Very Happy
It seems to work, and it seems to work by using a counter who's value is shifted around, and so the values will be unique, and then my breathing stops and my head spins and I have to start all over again.
The NOR makes for an oscillator that can be started and stopped at will, but how does it interact ...
Falk
G2 patch files: 29
PostPosted: Thu Jun 14, 2007 3:54 am    Post subject: Re: New try, and this a puzzler Reply with quote  Mark this post and the followings unread
Hello Blue.
For things to work correctly with all this shifting, feedback and S&H I needed 3 rising flanks in one clock cycle.
Clock, inverted clock and the deep magic, the NOR gate with feedback.
Are you traveling on the path of enlightenment yet?
/Falk
PS. Once I get home from work I'll post a more verbose explanation. DS
Audio files: 213
G2 patch files: 319
PostPosted: Thu Jun 14, 2007 5:36 am    Post subject: Re: New try, and this a puzzler Reply with quote  Mark this post and the followings unread
Only in the sense that I can see where the number 3 comes from, not what it is good for thinking
It would maybe help when I wouldn't be supposed to be working Laughing
Falk
G2 patch files: 29
PostPosted: Thu Jun 14, 2007 11:51 am    Post subject: Re: New try, and this a puzzler Reply with quote  Mark this post and the followings unread
Hello Blue.
I have added a manually clocked version that shows what is in the shift registers without having to sample it. As is, it doesn't perform any mixing operations.
Once you understand how the injector and the shuffle works, move the connector from the Seed input of the Mix Source and insert it into the empty socket on the AND gate.
Add a new module and remove it again to ensure that the patch is recompiled and then see how the random signal affects the shift registers.
Now, the NOR gate. As I said, this patch needs three rising flanks during each clock cycle. They need to be in a specific order and they must not be simultaneous.
First the injector and the shift registers needs to be clocked. Then the Mix Source needs to be clocked. Thirdly the S&H 1-2 and S&H 3-8 needs to be triggered.
Because we do not know how the Clavia patch compiler splits the signal/logic workload in 4 pieces it is possible that piece 1 use an output from piece 2, piece 2 change its output and piece 3 use the 'same' output from piece 2 but now piece 1 and 3 have different opinions on what that value is even though it looks like the same wire on screen.
The magic of the NOR gate is that when the input is high/true the output is low/false. When the input goes low, the output starts to oscillate at 12 kHz. This is due to the feedback from the output to the other input. Because of the feedback, it doesn't start until the next 24 kHz clock cycle.
Thus, 3 rising flanks from one clock, the clock itself, the inverted clock and the NOR gate that produces a 12 kHz clock burst one 24 kHz clock cycle after the inverted clock.
The S&H modules doesn't care if they are triggered multiple times as long as the pulse train stops before the input changes its value.
That wasn't so hard was it? Wink
Oh, I have also managed to remove 2 modules from the Injector Twisted Evil
The picure hopefully helps to visualize the mixing of the shift registers.
/Falk
An illustration of how the random mixing works
 Filesize:  2.77 KB
 Viewed:  24288 Time(s)
DemoShuffleMix8.pch2
A manually clocked Shift&Mix 8-in/8-out shuffle with shift registers
 Filename:  DemoShuffleMix8.pch2
 Filesize:  1.71 KB
 Downloaded:  864 Time(s)
Falk
G2 patch files: 29
PostPosted: Fri Jun 15, 2007 12:42 pm    Post subject: Just showing off.......
Subject description: Even more optimized
My computer science background is really showing off tonight..... Embarassed
I managed to get rid of one of the shift registers and the injector is finishes in 7 steps, not 8.
20% CPU and 30.5% memory compared to 20.8% CPU and 36.7% memory of the previous version (the earlier sbt_shufflepatch_8_falk.pch2 used 21.3% CPU and 39.1% memory).
falk_shuffle_8_v3.pch2
 Filename:  falk_shuffle_8_v3.pch2
 Filesize:  1.83 KB
 Downloaded:  856 Time(s)
Audio files: 213
G2 patch files: 319
PostPosted: Sat Jun 16, 2007 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for not having found time yet to go on with/into this - got some time consuming other things.
I saw this was posted as a building block - it seemed appropriate to link it from here : http://electro-music.com/forum/post-124787.html
