 Forum index » Clavia Nord Modular » G2 Performances - Completed
Lo Promotion
Page 1 of 1 [5 Posts]
Stanley Pain
Audio files: 10
G2 patch files: 35
PostPosted: Tue Aug 07, 2007 9:30 am    Post subject: Lo Promotion
Subject description: HELP NEEDED!!!
ok, here's a patch that i've written recently, specifically for live performance.
the problem is this. it's designed to fit in with sequences running off ableton.
there doesn't seem to be an issue with it syncing, in fact, i've never found there to be sync issues betwixt ableton and the G2.
however, slot C doesn't seem to want to sync up properly. this is annoying to say the least. my "work around" is pretty make shift and slapdash, and involves moving everything a on SLOT C's sequencers a beat early, and delaying the signal manually using the delays coloured red at the end of SLOT C's sequencers.
ugly ain't it?
if you have any idea what the problem might be, please could you shed some light on the matter?
thanks!
lo promotion.prf2
without workaround
 Filename:  lo promotion.prf2
 Filesize:  13.39 KB
 Downloaded:  1344 Time(s)
lo promotion 2.prf2
with work around
 Filename:  lo promotion 2.prf2
 Filesize:  13.17 KB
 Downloaded:  1318 Time(s)
there's no I in TEAM, so let's all act as individuals instead
G2 patch files: 625
PostPosted: Tue Aug 07, 2007 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Stanly
Really nice prf.
I am not sure exactly what your after and dont have any external sync to test things with.
I've tried a bit of rewiring that at least gets rid of the glitch where two or more sequencers run at the same time after a stop start. I have that problem a lot.
lo_promotion_IS.prf2
 Filename:  lo_promotion_IS.prf2
 Filesize:  13.38 KB
 Downloaded:  1625 Time(s)
3phase
G2 patch files: 141
PostPosted: Wed Aug 08, 2007 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
cant check it wright now but from a quick view i get that the clock active outputs are not pulsed and therfore are permanently high what overwrites the syncing of some modules..maybe your problems are related to that...
i see if i can have it running with ableton later...
iPassenger
G2 patch files: 78
PostPosted: Wed Aug 08, 2007 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice patch, seems like the bass isn't resetting with the clock either, so I modified, I know you hadn't asked for that so ignore me if ya like.
lo_promotion_599.prf2
 Filename:  lo_promotion_599.prf2
 Filesize:  13.58 KB
 Downloaded:  1154 Time(s)
iP (Ross)
Stanley Pain
Audio files: 10
G2 patch files: 35
PostPosted: Wed Aug 08, 2007 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks for all the replies. i'll be checking first thing in the morning! but now... to sleep...
